I have a nd-2510a writer but cannot get it to write to dual layer discs can anybody help please
mickdee259..........
http://www.herrie.org, click the Firmware option on the left side, follow your way to the one you want. I'm using it, it works like a charm.
What kind program do you use to burn?
Please specify your problem a little bit more -
I use nero most of the time but it won`t write useing roxio either
mickdee...... -
Check if your version of Nero supports writing D/L discs.Originally Posted by mickdee259
NEC NDH80 Gone B&W
By bawpcwpn in forum DVB / IPTVReplies: 1Last Post: 11th Jun 2008, 15:23 -
NEC AD-5170A Questions
By urb1972 in forum DVD & Blu-ray WritersReplies: 1Last Post: 24th Nov 2007, 21:39 -
NEC DVD Drives
By RapidRio in forum Newbie / General discussionsReplies: 1Last Post: 5th Jul 2007, 14:13 -
NEC 4571A problem
By rmorrison1 in forum DVD & Blu-ray WritersReplies: 18Last Post: 1st Jul 2007, 13:35 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05
