Hi,
I have a strange problem that occurs when I hook my dvd recorder to my analog satellite receiver or vcr.
The dvd recorder is not plugged on the same power as the vcr or sartellite receiver.
Here is what I get when thet are hooked (it's taken from the dvd recorder but I have the same display on the tv).
On this picture, the "white" horizontal bars move slowly upwards.
On this picutre the picture "jumps" and the colorful artifact move downwards.
On this, the picture is deformed by a kind of big wave.
All these 3 things appears at the same time.
This only occurs when my dvd recorderd is hooked to the satellite/vcr.
Now, here is how the are connected
Satellite/TV/VCR are connected to the same power plug (with a multiplug).Code:Analog Satellite => scart1 => output to AV1 of TV set => scart2 => output to DVD Recorder VCR => scart1 => AV2 of TV set or to DVD recorder when needed
My DVD recorder is connected to the same powerplug as my computer
Now, when these artifact appears, if I unplug the UPS and replug it they disappear for several days. I absolutely need to unplug the UPS (power it down and up won't resolve the problem).Code:PowerPlug => multiplug => Plug1 => UPS => Computer => Plug2 => DVD Recorder
What may be the source of this problem ??
Ground loop. Power from same outlet and see if problem stops.
I've made several tests by pluggin muy devices to others power points in the house.
It seems that all the power plugs on the same circuit cause problems. I tried pluggin it with a long power cable to another point in the house and there is no problems.
So how can I resolve this problem ? It's quite annoying when I want to record something because I need to unplug my UPS (and the computer at the same time).
How can I fix this ground loop or how can I test the efficiency of the ground in, my sleeping room ??
Thanx
Strange things happens in my VCD menu
By Douglas879 in forum Authoring (VCD/SVCD)Replies: 0Last Post: 28th Nov 2010, 03:07 -
MeGUI: Strange things in overall ripping process
By tom.tlr in forum Blu-ray RippingReplies: 0Last Post: 19th Sep 2010, 11:47 -
Strange issues with VLC Media Player, No sound and distorted picture
By xoADAMox in forum Newbie / General discussionsReplies: 3Last Post: 28th Feb 2009, 15:58 -
downloaded video files doing strange things
By ouiglz in forum Newbie / General discussionsReplies: 6Last Post: 26th Jan 2008, 14:37 -
Strange display problem with VLC
By marioval in forum Software PlayingReplies: 7Last Post: 19th Nov 2007, 13:31
