  1. I have just merged two SVCD files into one using VideoReDo. I played the output file in VideoLAN and the length of the clip was roughly 30:00 while the combined length of the files is over 100 minutes. The whole two clips are there but the time length is wrong and so the seconds counter ticks alot slower. Is this just VideoLAN or is there a problem with the clip? any help would be appreciated.
    Many thanks.
  2. How long are each of the clips? Does the sum match that of the Videoredo playback length for the combined clip? If Videoredo says it is correct then it would seem the problem is with Videolan.
  3. Just checked in VideoReDo and the time is much more accurate. However the combined length of clip 1 and 2 = 102:43 but my new merged clip is 97:09. Where has the remaining 5 minutes gone?
