I just need to extract the video file without the menu.I can extrack the menu and video file(vias vobblanker,but i only want the video clip
So is this possible?
Thanks!
Steve
Thanks for your help but i can still not extract the video file without the menu
No matter what i do the menu is attached to the video file... -
When you say (Menu) you mean the video has the "Play" "Extras" WORDS on the Video?
It maybe because they are static on the Video. If so you cant get just the video. -
No, the menu is part of the video file. It is usually hardcoded into the video.
ICBM target coordinates:
26° 14' 10.16"N -- 80° 16' 0.91"W -
Yes the menu is attached/interlinked with the video,so yep looks like they cannot be separated, thanks anyway
How to extract pictures from a dvd video file?
By tkirby in forum EditingReplies: 3Last Post: 3rd May 2009, 01:46 -
How to extract video from ots file ?
By JN in forum Video ConversionReplies: 2Last Post: 14th Feb 2009, 01:21 -
Software suggestions for video clip or motion menu at the beginning of DVD?
By hitman3000 in forum Authoring (DVD)Replies: 2Last Post: 14th Mar 2008, 20:30 -
How to extract an AVI clip from a ts video file?
By alegator in forum Video ConversionReplies: 5Last Post: 10th Mar 2008, 20:48 -
Is it possible to extract the video from a motion menu?
By mjvgiese in forum DVD RippingReplies: 2Last Post: 3rd Dec 2007, 22:31
