Having problems making VCD's
TDK Reflex CDRs burn "successfully" but there is no data reported on the disk by windows explorer. Unbranded CDRs fail immediately with block beyond end of track error. Samsung CDRs work OK.
Is this a CDR brand problem or program/hardware. Using EZCD 4 delux and Phillips PCRW404 drive. Help appreciated.
PS I can't source the Samsung disks at the moment but have loads of the others
Depends, is this happening ONLY with this type of media ? it could be incompatible with your drive.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
I've had similar problems with EZCD 4 when trying to create VCDs. I'd suggest that you try VCDEasy (which can be downloaded from this site) and see if you get better results.
EZCD is for Music Burning only in my case i hate EZCD..i would suggest CDRDao with the XDupilcator GUI or NERo to burn my stuff
Thanks, will try your suggestions
Sefy - these are the only media I have tried. In the case of the TDK you can actually see the burnt area but it reports empty! -
You do know Windows Doesn't report the full size of VCD
It only reports the size of the files, not the movies.
If u disk is 700megs, windows may only report 1.34megs used.
It "see's" but doesn't report the VCD movie files because they aren't written the same as data. -
Do the CD's you burn work on another PC ? or better, do they work on a DVD Player ? cause if they do, it just might be a problem in the PC, and that can always be narrowed down and fixed.
Best Regards,
Sefy Levy,
New burner burns SLOWLY
By will7370 in forum Newbie / General discussionsReplies: 14Last Post: 23rd Feb 2012, 21:01 -
New PC Burns With Errors
By NOIC in forum DVD RippingReplies: 22Last Post: 29th May 2009, 12:12 -
burns fails. help
By dymx in forum Newbie / General discussionsReplies: 8Last Post: 18th Jun 2008, 13:54 -
Bad burns
By jalfirov in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2007, 13:14 -
Bad Burns
By jalfirov in forum Authoring (DVD)Replies: 1Last Post: 16th Aug 2007, 03:23
