  1. Can someone please explain how I can fix the problem. I have a DVD movie (video_ts folder) that seems to have the audio sound 200 miliseconds faster than the video.
    I have ripped the (dvd decrypter) movie to my HD and I am prepared to fix it on my pc and burn it back onto another blank dvd. I have googled for the information, but can't really find anything specific.
    I gather it can be done using ifoedit and/or vobedit.
    Can anyone point me in the right direction with instructions on what to do.
    thanks.
  2. Originally Posted by amichael
    thanks.
    1. Use Vobedit to demux the files you created with DVD Decrypter.
    2. Use IFOEdit to Author New DVD and select the .m2v and .m2a files created in step 1.
    3. You can input the amount of audio delay needed.
  3. thanks for that. I' give it a quick go. The original dvd has 5.1 sound so I hope it ends up th the same audio.
  4. Hi again,
    OK I demuxed the mpeg stream and ac3 audio of each of the 5 vob files. So I got 5 sets of new files. (m2v + ac3)
    Going into ifoedit , I chose author new dvd and it only lets me choose one of the sets . How do I add the rest of them ? I can't see how you add the rest of them.
  5. Originally Posted by amichael
    Hi again,
    Select only the first .VOB file in the title set before you de-mux with VOBEDIT. Select all video and audio (subtitles also if you have them) streams. VOBEDIT will automatically load in all the other .VOB files.
  6. yep it worked fine although I could never get the audio in sync unil I read another recommendation to enter a minus 200 figure. Even though an error pops up you can still enter the minus no. all is good now and in sync.
  7. Wow, nice little thread, guys. I didn't know you could do this w/VOBedit & IfoEdit.
    I have some homemade DVDs of Tivo programs that could benefit from this, and will give it a try!
