I am about to lose my mind. I know someone here knows exactly what to do so here is my scenario. I've looked for an answer and nothing seems to work.
I have been given a task to rip certain portions of scenes from multiple DVDs and put them all together into one DVD-R. Looking at the guides I ended up using DVD Shrink to extract the exact time needed, for example from 1:20:45 through 1:28:30. I extracted these scenes to files, VOB to be exact. All was going fine up until then.
Initially I tried loading these VOB files to Premiere, couldn't. I couldn't load them even if I renamed them. I then proceded to convert them. I tried VideoReDo to generate MPG files. They seem fine up until you try using them in Premiere. Then I tried creating AVI files with VirtualDub-MPEG2. So many settings...and still had problems with video/audio not in sync. I then tried to create M2V/AC3 files. I extracted them but AC3 wouldn't load into Premiere. I converted it to WAV. Then I loaded the M2V just to find out that it doesn't play right. It plays too fast.
So to recap, I've tried AVI, MPG, native VOB, and even M2V/AC3/WAV and nothing has worked with Premiere. What am I doing wrong?!??!? Premiere is what we have and I need to put a 3-sec title before each clip. All help is greatly appreciated.
Oh and by the way, I have to maintain a 16:9 widescreen format, which my Premiere project matches. Does it have something to do with the frames per second??? Help!
Ed
Premiere was not made to edit Mpegs without 3rd party plugin.
Use Virtualdub-mpeg2 to convert to one of the following AVI Codecs:
a) Uncompressed RGB (no codec needed but very large)
b) Huffyuv (need codec, I recomend v 2.11)
c) DV-AVI (need codec, Panasonic is free)
The first two are lossless. The last is a little lossy, but very editable. -
I've tried VirtualDub already, but I will try it with the codecs you recommend. Any other settings that I need to set within the program? There are so many settings.
The problem I had with the AVIs was that they video and audio didn't stay in sync or that it didn't stay in the correct pixel aspect ratio. I don't see pixel aspect ratio settings in that program.
So basically stay away from MPG for Premiere. I should use something like an AVI? I'll try it and will post a response. -
pixel aspect ratio shouldn't change. You will have problems if you have ripped a mixture of 16:9 and 4:3 footage. I also suggest you don't just but the clips up against each other, but add a small cross fade or even better, fade out to black, then fade back in to new clip. This will allow you to manually correct any sync problems on a per clip basis without affecting any other clip.
Read my blog here.
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
Putting lot of small clips toggeter
By red_d in forum Video ConversionReplies: 2Last Post: 7th Mar 2008, 22:51 -
Small MPeg clips From Cam
By vinnyv07 in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 2nd Jan 2008, 15:28 -
How to create small clips from a movie!
By unstopabl3 in forum Newbie / General discussionsReplies: 3Last Post: 27th Dec 2007, 05:34 -
Small Quicktime Clips in a Premiere Pro Project
By foochuck in forum Newbie / General discussionsReplies: 0Last Post: 25th Jul 2007, 23:27
