Results 1 to 10 of 10
  1. use to work fine then installed some new codecs and now no video playback at all. tried using windows media player as well as VLAN and nothing seems to work. here is a list of all codecs g-spot recognized.
    DMO WMVA WMVideo Advanced Decoder DMO Microsoft Corporation qasf.dll --> wmvadvd.dll
    DMO MP4S Mpeg4s Decoder DMO Microsoft Corporation qasf.dll --> mp4sdmod.dll
    DMO MSS2 WMV Screen decoder DMO Microsoft Corporation qasf.dll --> wmsdmod.dll
    DMO WMV2 WMVideo Decoder DMO Microsoft Corporation qasf.dll --> wmvdmod.dll
    DMO MP43 Mpeg43 Decoder DMO Microsoft Corporation qasf.dll --> mp43dmod.dll
    DMO MPG4 Mpeg4 Decoder DMO Microsoft Corporation qasf.dll --> mpg4dmod.dll
    DSH DV Video Encoder qdv.dll
    DSH Indeo® video 5.10 Compression Filter Intel Corporation ir50_32.dll
    DSH MJPEG Compressor quartz.dll
    DSH Nero Digital AVC Video Enc Nero AG NeNDVid.ax
    DSH MPEG Video Decoder quartz.dll
    DSH DirectVobSub (auto-loading version) Gabest DVobSub.ax
    DSH MSS1 Microsoft Screen Video Decompressor Microsoft Corporation msscds32.ax
    DSH WMV1 Windows Media Video Decoder Microsoft Corporation wmvds32.ax
    DSH WMV2 Windows Media Video Decoder Microsoft Corporation wmv8ds32.ax
    DSH XVID XviD MPEG-4 Video Decoder xvid.ax
    DSH DIV1 DivX MPEG-4 DVD Video Decompressor Hacked With Joy ! DivX_c32.ax
    DSH DVC DV Video Decoder qdv.dll
    DSH DIVX DivX Decoder Filter
    DSH InterVideo Video Decoder InterVideo Inc. ivivideo.ax
    DSH IV50 Indeo® video 5.10 Decompression Filter Intel Corporation ir50_32.dll
    DSH IV41 Indeo® video 4.4 Decompression Filter Intel Corporation ir41_32.ax
    DSH AVI Draw quartz.dll
    DSH Video Port Manager quartz.dll
    DSH MJPEG Decompressor quartz.dll
    DSH AVI Decompressor quartz.dll
    DSH QT Decompressor quartz.dll
    DSH Nero Video Decoder Nero AG NeVideo.ax
    DSH Nero DVD Decoder Nero AG NeVideo.ax
    VFW CVID Cinepak Codec by Radius Radius Inc. qcap.dll --> iccvid.dll
    VFW DIV3 DivX MPEG-4 Low-Motion Hacked with Joy ! qcap.dll --> DivXc32.dll
    VFW DIV4 DivX MPEG-4 Fast-Motion Hacked with Joy ! qcap.dll --> DivXc32f.dll
    VFW HFYU Huffyuv v2.1.1 - CCESP Patch v0.2.2 Disappearing Inc. qcap.dll --> huffyuv.dll
    VFW I420 Intel 4:2:0 Video V2.50 Microsoft Corporation qcap.dll --> msh263.drv
    VFW IV32 Intel Indeo(R) Video R3.2 qcap.dll --> ir32_32.dll
    VFW IV41 Intel Indeo® Video 4.5 Intel Corporation qcap.dll --> ir41_32.ax
    VFW IV50 Indeo® video 5.10 Intel Corporation qcap.dll --> ir50_32.dll
    VFW IYUV Intel IYUV codec Microsoft Corporation qcap.dll --> iyuv_32.dll
    VFW M261 Microsoft H.261 Video Codec Microsoft Corporation qcap.dll --> msh261.drv
    VFW M263 Microsoft H.263 Video Codec Microsoft Corporation qcap.dll --> msh263.drv
    VFW MRLE Microsoft RLE Microsoft Corporation qcap.dll --> msrle32.dll
    VFW MSVC Microsoft Video 1 Microsoft Corporation qcap.dll --> msvidc32.dll
    VFW VP60 VP60® Simple Profile On2.com qcap.dll --> vp6vfw.dll
    VFW VP61 VP61® Advanced Profile On2.com qcap.dll --> vp6vfw.dll
    VFW XVID XviD MPEG-4 Codec qcap.dll --> xvidvfw.dll
    please can someone identify which ones are conflicting and are casuing my playback problem and how to uninstall them. i am running windows xp if that helps as well with a geforce 4 440 go card. thanks in advance
  2. forgot to add the video shows up in tmpgenc when working with it.
  3. Member normcar's Avatar
    Aug 2003
    USA - IL
    I would try Divx. I never use Windows Media Player. I also use WinDVD for playing DVDs and MPGs.
    Some days it seems as if all I'm doing is rearranging deck chairs on the Titanic
    Dec 2004
    Australia
    IF VLC doesn't work, then it isn't a dshow issue.
    Perhaps directx got messed up?
  5. Member Skith's Avatar
    Bottom of the ocean
    which codecs did you install? try uninstalling those. Did you use a codec pack? (I hope not!) - If you did, uninstall the codec pack, or better yet, all codecs, and reinstall. You could also try loading a restore point (if you have system restore enabled).
    Some people say dog is mans best friend. I say that man is dog's best slave... At least that is what my dogs think.
  6. i tried uninstalling all codeds but nothing. any other ideas?
  7. Holy Moly! That's too many codecs jammed together, many of them obsolete already.
    You only need following installed: Divx5.21, Xvid, ffdshow, AC3 filter, OGM and Matraska filters, plus QT and RM. And use Classic Media Player. I have yet to meet a format this combo couldn't handle!
    Stay away from codec packs. They are nothing but trouble.
    Dec 2004
    Australia
    Well technically. XviD can decode DivX, ffdshow can decode both as well as AC3. So no need for AC3Filter either.
    So from your above list you only need ffdshow and ogm/matroska splitters.
  9. Member Skith's Avatar
    Bottom of the ocean
    Mabey I am just unlucky, but I can never get FFDshow to work right. It always mucks something else up.
    I use Media Player Classic or The Core Media Player (TCMP), DivX, Xvid, ogm/matroska, quicktime alternative, real alternative.
    (TCMP installs support for ogm, AC3, matroska - v1.0.3 I think.) It can also install FFDShow (whichever version is included, though I usually deselect that option).
    It could also be that I don't have a clue what I am doing with FFDShow
    Dec 2004
    Australia
    Newer installers ask you what video and audio formats you want ffdshow to handle as well as some of the audio/video filter options. Really no need to setup ffdshow afterwards that way.
    But yeah, ffdshow is a bit of a complicated beast. Kinda has to be when it supports as much as it does.
