i've never burnt a dvd in my life, so im really clueless. i don't have a dvd writer in my pc and i'd like to know if its possible to convert an avi(divx) file to a svcd file and burn it(using nero) to a cd-r and play it on my dvd player? (it supports svcd). if the file is 700mb will it be bigger when its converted to svcd? cd-r only hold about 800mb so will i have to split the avi? is this complicated? should i give up now and save myself a load of grief?
Since you already have what you need, go ahead and make a SVCD. For a regular length movie, you will need 2 CDs.
You might go with DVD2SVCD. It takes care of most of the complex operations. It also splits the finished file for 2 CDs. You can use the trial version of TMPGEnc. If you are starting with a AVI, it needs to be a format DVD2SVCD understands. Some DIVX or XVID may need further conversion.
I'd leave Nero out of the equation, except for maybe burning. It does that fine, but not a lot more. (IMO)
And save up for a DVD burner, you will be much happier.
Help with HF200 (24p and 30p question) technical question
By Coldbricks in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 15th Jun 2010, 14:24 -
Mod16 question and DAR question...
By alcOre in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2008, 16:18 -
Age old question of VHS to DVD question...I still don't get it.
By saywhat? in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2008, 23:43 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18 -
Patching SVCD to DVD question
By zanos in forum Authoring (DVD)Replies: 22Last Post: 29th Jun 2007, 10:17
