When trying to rip Cats and Dogs DVD using Smartripper I keep getting errors on a blue screen stating
WINDOWS PRETECTION ERROR - PLEASE RESTART COMPUTER.
Is this protection on the DVD or a system problem
Any info is appreciated.
Has it worked before, I use to get the same error with the newer versions of smartripper with windows ME, I had to use an older version, when I went to windows XP the problem went away, you can also try cladDVD or vstrip.
I ripped this movie using SmartRipper 2.39 & Windows ME with no problems at all
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
AutoGK, DVDShrink, SmartRipper won't recognize stream language/info
By takearushfan in forum AudioReplies: 5Last Post: 26th Sep 2009, 20:21 -
SmartRipper -- question about "Search Intensity" setting
By Dr.Rock in forum DVD RippingReplies: 1Last Post: 30th Dec 2008, 14:26
