Hi!
If you are facing problemtrying to burn the cd image created by Philips VCD toolkit, this article may help:
How to burn disk image created by Philips VCD Toolkit 2.0 Using Nero
Good Luck!
uttam
You have to convert the image to BIN/CUE. In the zip file "vcd2tk" there is an other zip called "tocs12", you have to extract the zip file in a folder, then use "tocsplit" and load the toc file (Philips Video CD Toolkit' s image), check the setuo (I use BIN/CUE file) and press "GO!". Ensure that you have free space for the converted image. Then you can burn it with Nero.
I hope that it will be helpfull.
Will the created BDMV burn correctly and start at the beginning?
By pepegot1 in forum Blu-ray RippingReplies: 2Last Post: 5th May 2011, 07:37 -
question about how to burn Nero Image
By jimdagys in forum DVD RippingReplies: 5Last Post: 4th Sep 2010, 11:06 -
Image Burn SLIP
By wulf109 in forum DVD & Blu-ray WritersReplies: 1Last Post: 28th Jan 2010, 15:18 -
DVD Flick created image distortion
By Vianty in forum Authoring (DVD)Replies: 7Last Post: 28th May 2009, 02:17 -
Erase BD-RE with Image Burn?
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 29th Feb 2008, 13:34
