Hi. I'm currently using a SoundBlaster 64V PCI (ensonique) which is not good enough for capturing, it goes without saying.
Can anyone recommend a good soundcard for capturing - I've heard creative cards eat up a lot of resources? one with digital optical out would be good too, because I can then use it with my MD, but that's NOT essential.. I was looking in the £40-£60 region...
Thanks!!
I used to capture with the chipset audio of my motherboard but the sound was horrible. I just bought a Hercules/Guillemot fortissimo 2 and it sounds great. It has both digital input and output.
does anyone else have any reviews or views on this soundcard? I'm going to buy it I think, but want to know it's a decent card... how does it fare when it comes to CPU usage?
The Videologic Sonicfury is a very good buy, same basic card as the TB Santa Cruz. You should be able to pick one up for <>£60 if you shop around.
Substitute a USB audio device for dead laptop soundcard? [SOLVED]
By usually_quiet in forum ComputerReplies: 14Last Post: 2nd May 2011, 00:17 -
Capture video from DV-camera and audio from soundcard
By NiQ in forum Capturing and VCRReplies: 1Last Post: 25th Mar 2010, 12:57 -
capture soundcard output stream
By ted demen in forum AudioReplies: 0Last Post: 6th Mar 2009, 21:07 -
Lightweight soundcard recorder?
By andy_blah in forum AudioReplies: 1Last Post: 24th Aug 2008, 21:11 -
Soundcard problem I think
By rock.freak667 in forum AudioReplies: 2Last Post: 23rd Apr 2008, 18:51
