  1. Hi!
    First, I need to rip one cd with numerous tracks on it, to just one track.. or i need to merge all the tracks together without creating clicks and such between the tracks (I use EAC to rip normaly)
    Second, I need to merge 2 cds together, I have a concert splitted onto 2 discs, so i want it to be in one big file instead for a dvd project.
    Can anyone help me with this?..
  2. Member Sifaga's Avatar
    Aug 2003
    Melbourne, Australia
    Hi
    First: CDEX can do this, open cdex then go convert/extract a section of the CD (F10) then you can choose a start and end position.
    second: any audio editor can do this maybe audacity or cool edit
  3. Thanks!.. will try those
    Dec 2004
    Australia
    EAC can do it also.
