just wondering if it is possible to convert iso files to divx because my home dvd player plays divx too. i have a couple movies on my computer that are in iso format that i have to use deamon tools in order view it. is there away to convert it to divx so i can watch it on my tv?
extract the content from the iso and convert to divx. if dvd then use for example fairuse wizard.
ok i used winrar to extract the files. i now have 2 folders names AUDIO_TS and VIDEO_TS. now when i open the audio folder there are no files but there are files in the video folder but when i play it there is still sound. So now my next question is how do i proceed from here to convert this to divx?
I don't generally convert dvds to divx, but since Baldrick suggested FairUse Wizard, I would try that if I was you.
There's a guide on how to do just that here.
The only change for you would be in step two. In the current version of FairUse Wizard, there is now a second box down below the "drive select" that allows you to select an iso file.
Other than that, I would try just following the guide.
Good luck. -
I'd mount the ISO (which obviously is a DVD image) with Daemon tools, and from that point on, treat it as any DVD to DivX conversion case, for which there are numerous methods.
(As I now see I'm not the first to suggest
/Mats
Tool recommend for *.avi ---> DVD(iso) and ripping a DVD to *.iso file?
By pxstein in forum Authoring (DVD)Replies: 4Last Post: 11th Jan 2011, 16:51 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 19:13 -
I convert mpeg2 to iso, then what? Can I covert iso to VOBs?
By BeerSnob in forum Newbie / General discussionsReplies: 3Last Post: 1st May 2008, 19:01 -
Converting ISO to AVI (Divx or Xvid)
By cyberjackal in forum Video ConversionReplies: 2Last Post: 11th Jul 2007, 11:50 -
UDF or ISO when burning a multi DivX DVD-R
By perceptionist in forum DVD RippingReplies: 3Last Post: 4th Jun 2007, 14:10
