Just bought and installed my pioneer 109 afyter my 107 died on me. Thing is stomp tells me there is no compatible recorders on my pc. Also nero will only give me the option of burning at mx 2.4 2 or 1 speed, even when i open up disc juggler the maximum speed is 4. Firmware ersion is 1.40. Any help appreciated.
Depending on which version of Stomp you have it is possible to get it to work with a Pioneer 109, there's a thread on here about the 4.5 version anyway. Update Nero and Disc Juggler to the latest versions, should do the trick.
He's a liar and a murderer, and I say that with all due respect. -
do you have blank DVD media that will support anything higher than a 2.4X speed?
the DVD writer identifies the max recording rating from the info on the DVD+R.
for example, i have a TDK 420N... it will record at 4X, but the disks i have are rated 2.4...
when i put a disk in, it always locks out anything higher than 2.4X
im kinda new here so someone correct me if im wrong..
and i was curious if there was a way around that.. can you black out the boot ring(i dont know what its called) and record at 4X anyways?computer sciences
multiAVCHD - (RT) Invalid array index. Array is empty - Line 109.
By JackyWang in forum Authoring (Blu-ray)Replies: 3Last Post: 25th Oct 2011, 09:53 -
NeoDivX 2008 3002.0.1.109
By zebbra in forum Newbie / General discussionsReplies: 5Last Post: 5th Aug 2008, 23:20 -
How do I update the firmware on my Pioneer 109 DVR?
By Boogie7910 in forum DVD & Blu-ray WritersReplies: 2Last Post: 26th Nov 2007, 05:44 -
VideoInspector updated to v1.10.2.109
By Kyle_Katarn in forum Latest Video NewsReplies: 0Last Post: 20th May 2007, 15:03 -
Changing the internal PIONEER DVD-RW DVR-109 Drive's Region Settings
By vidmarc in forum MacReplies: 5Last Post: 4th May 2007, 09:48
