Hi everyone.. I tryed such hard to make a loop between dos chapters of my dvd without success. I need a loop between chapter 01 and 09 and another between chapter 10 and 15. Anyone can explain to me how to do it?
THANKZ A LOT
xperman
Not sure I understand what you mean by loop. Do you mean you want to be able play through chapters 1- 9 as one title, and chapters 10 - 15 as anothor ? If this is the case, DVD Lab Pro and DVD Architect use the concept of playlists to link just some chapters for playback from a single point.
Read my blog here.
Can DVD Architect do Chapter Playlists? I have been using the Trial of DVDA3 (just released), just to see if it might be worth moving to (because it supports multi angles). I couldn't find where to add Chapter Playlists. It's probably there, but I just haven't seen it yet. I'll keep looking if you confirm it can do Chapter Playlists (i.e. play only Chapters 1, 3, 5 of a 7-chapter title).Originally Posted by guns1inger
ThanksGeorge -
OK i did tryed without succes. DVD architect write a PCG chain that's not avariable for many DVDplayers (prosumers players). My main idea is to create a DVD with 2 or more playlists. that's correct. for example: main menu with 3 buttons 1.tango 2.bossanova 3.rockandroll and any of this buttons link to a chapter. the button tango goes to chapter 01 and untill chapter 05 in my DVD are tango videos. the second button does the same but goes to chapter 06 and untill the chapter 10 in my dvd are bosanova videos and so long..........
ANyone can explain how to change my PCG chain created by any author just a model or an example how to do it will really help to me,. THANKZ A LOT -
I think all the DVD authoring tools can do what you want to do, except maybe for the looping part. For example, I know for sure that TMPGenc DVD Author can create this. You can create 3 "tracks", each with the chapters you want to loop, and a menu with the three tracks.
The looping part is easy to add after the fact. Assuming the chapters you want to loop are in the same PGC (which should be the case) it's just a question of adding a LinkTopCell command as the cell command of the last chapter for example.
xperman, you don't give enough details for us to help you. I'm sure DVD architect can do what you want to do, but I don't have it so I can't help you. Tell us what you have now, and we'll help you add whatever else you need.
jeanlMenuShrink a free tool to shrink menus into stills with or without audio!
DVDSubEdit: a free tool to modify your subtitles directly inside the vob.
How can I edit chapters on DVDs?
By Putts in forum Newbie / General discussionsReplies: 28Last Post: 21st Mar 2010, 15:14 -
how to find which VTS/PCG for a given title ?
By halsboss in forum DVD RippingReplies: 3Last Post: 15th Jan 2010, 13:33 -
i'm out of the loop..could someone update me?
By 91rtstealth in forum MacReplies: 6Last Post: 6th Nov 2008, 18:48 -
sony vaio pcg 8n2m laptop
By Mr anderson in forum ComputerReplies: 5Last Post: 7th Nov 2007, 15:25 -
C# loop issue
By Darth Paris in forum ComputerReplies: 7Last Post: 23rd Oct 2007, 19:36
