I have several different dual audio clips (AVI) from different sources. I am trying to play them through Window Media Player 9 using Morgan Multimedia Stream Switcher. On all of them, the audio cuts out after some time. On the 20 minute clip, the audio cuts out after 4-10 seconds. On the 1.5 hour clip, the audio stops after about a minute. I can get the audio back temporarily by clicking on the position bar (which also makes the movie jump to a different location) or by switching the audio track.
I swear I have searched extensively for this topic, but I've only seen it posted once before (on a website I don't remember) with no responses! Someone please help.
All the clips are coded with AC3 to the best I can remember. I'm using XP SP2 with Windows Media Player 9, & use an ATI All-in-Wonder 9000 Pro. I have the latest Morgan Stream Switcher installed, downloaded direct from morgan-multimedia (v0.99). I've already tried uninstalling & reinstalling MMS. All single-audio clips play fine. The dual-audio clips play continuously when MMS is UNinstalled, so I'm pretty sure it's MMS or a conflict it has with something else.
Any ideas? Someone please help, I've been struggling with this for a couple months now & haven't been able to figure it out.
Results 1 to 9 of 9
Hi- thanks for the tip. I tried the Matroska/Haali splitter with better results, although not perfect. The audio cuts out for a split second every couple of seconds, so it basically sounds jittery. But at least it doesn't stop the audio track completely. Any other ideas/tips?
If you want to find out why WMP9 doesn't work. I would start by looking into the CPU usage of both players.
I lost audio for mp3's, .avi, mpg files, and Audio Switcher::Out
By HartsVideo in forum Software PlayingReplies: 13Last Post: 14th Oct 2012, 21:20 -
How to sync the dubbed audio to make a dual audio .avi
By Scotter in forum AudioReplies: 4Last Post: 24th Dec 2011, 16:17 -
How Could I change the default audio stream in a Dual or Multi Audio AVI fi
By worldperseus in forum AudioReplies: 3Last Post: 17th Jan 2011, 06:53 -
How do I rip a DVD to a multi-Audio or a DUAL-Audio AVI?
By KneeRow in forum DVD RippingReplies: 8Last Post: 23rd Jan 2010, 14:40 -
How do you separate an AVI file into a video stream and an audio stream?
By VidHunter in forum MacReplies: 2Last Post: 1st May 2008, 04:27
