Is there a tool I can use to convert an AVI file from Divx 5 to Divx 3 Low?
Results 1 to 9 of 9
virtualdub, video->compression and audio->direct stream copy, file-save avi.
but why convert to divx3? -
Well, other files I converted came to that size and the only difference between them and this one file were the codecs, so I thought I had to use the older codec for the result to be the same...
With all the lossy codecs you tell the codec what size you want (some directly, some indirectly via the bitrate). The codec then does whatever is necessary to make a file of that size.Originally Posted by pepperleaf
That's it exactly. Thanks for the help, Virtualdub worked, everything's perfect now.
Beta Announcement: DivX Plus Web Player 2.1, DivX HiQ and HTML5 Support
By porfitron in forum Latest Video NewsReplies: 1Last Post: 23rd Nov 2010, 13:20 -
Divx Bitrate Adjustment - Low Motion or High Motion? TmpgEnc Xpress 4
By Sliztzan in forum Video ConversionReplies: 5Last Post: 31st Aug 2008, 21:11 -
Audio very low after VIDEO_TS -> DivX conversion
By mistafro in forum ffmpegX general discussionReplies: 7Last Post: 28th Feb 2008, 19:42 -
Q about Divx Low-Motion.
By GangstaRap in forum Newbie / General discussionsReplies: 4Last Post: 7th Feb 2008, 21:29 -
Make an unplayable Xvid/Divx video play in a divx standalone Player
By AllenGorden in forum Newbie / General discussionsReplies: 4Last Post: 31st Dec 2007, 18:25
