  1. Hello people...
    I'm using Scenarist for some time now but there are some things not so clear still. I want to make a scene selection menu, where there will be some square areas and inside them I would like to see the first frame of the corresponding scene. I used Photoshop to create the background and I have defined these square areas as layers, though I'm not sure they are transparent, as I suppose they should be. I then import the psd in Track Editor area of Scenarist as a still menu with subpictures. Then I do not know how to proceed. What I'm I doing wrong?
    Please advice.
    Cavey
  2. Reading before posting (also in doom9) is something I have already done and still do in fact. Maybe I have missed the right posts.
    Cavey
    Jun 2005
    Poland
    Hi
    Something like that You can do with Encore. My basic softwere is Scenarist, and I never use scenarist to generate video. Do this by Adobe After Effects and import to scenarist motion menu - mpeg, Add subpictures....... You know what.
    P.S.
    You said: "I then import the psd in Track Editor area of Scenarist a still menu with subpictures". If it is still menu it could't be motion - i think
    Bartosz
