I have a movie (DVD) about galactic forces and mystical powers with swords powered by light beams, and I got it from a friend.
Anyway...It was full screen, stretched out, and I went into ifoedit to put it to 16:9.
Even at 16:9, it looks stretched as the ppl that filmed this movie filmed it like the rest of the series of galactic warrior stories. I learned that these were filmed at 2.35:1
How do I make a new DVD so that it shows up not stretched at all?
Results 1 to 9 of 9
I too, have a movie about Galactic forces and mystical powers. Did yours involve a certain Empire??? How about some creep dude with bad asthma??
In any case.. was the *fix* with IFOEdit easy?? I never used that program before..NEC 3500AG - Firmware 2.TG
LiteOn 16P9S - Firmware FS09
Taiyo Yuden 8X, FujiFilm 8X YUDEN000T02, Phillips 8X CMC MAG-E01-000.
DVDDecrypter, DVDShrink, DVDFab, Nero 7
Hauppage WinTV PVR 150
Dscaler, TMPGEnc Plus/Author, Canopus ProCoder, CCE. -
You have to resize this mysterious film, add black bars to get back to a compliant resolution, then re-encode. This will of course affect the quality. Or, you could return from the not-so-light-side and puchase an official release when the time is right.
Read my blog here.
May the mysterious unknown power be with you.
"The avalanche has already started; it is too late for the pebbles to vote." -
so what you're saying s1inger, is that I have to convert to (as high quality as possible) AVI file, add some black, and maybe reencode to a full screen? or 16:9...can u point me to a tutorial where this might be easiest?
What kind of player are you viewing this file with? Is it an actual DVD video_ts folder, and you're using a software DVD player? It could be that your player isn't properly unsqueezing the video, if it's an "enhanced for widescreen" anamorphic transfer.Originally Posted by nobody2000
So if that's the case, you can do a test -- burn a test DVD-RW and then play back with your DVD player, see if unsqueezes properly. I had a (legit!) DVD that refused to behave on any software player, it wouldn't go to widescreen, had to play in back in my trusty Toshiba DVD player to get the aspect ratio right.
And if all else fails, you could always go out to catch a movie in a theater, instead.
no...that's not it...I have other movies that play this aspect ratio fine on this same player
and who says that this movie's in the theatres?
I'm surprised that this hasn't been locked with a warning yet. I think everyone knows which movie you are talking about, anyway. So I would just follow everyone else's advice. They seem to have your solution.
If you want to make a 1.85:1 anamorphic movie appear properly at 2.35:1, you'll either need to squash it with some more black matting in an encoding program, or if you have a 16x9 TV, there is another solution:
Set your DVD player to 4:3 Letterbox, and set your TV to fill the screen by stretching the picture horizontally (often called Full mode). It should display in 2.35:1 with no distortion.Knowledge is Power, For Real!
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 13:13 -
Fixing horizontally stretched video
By robjv1 in forum EditingReplies: 7Last Post: 10th Sep 2010, 03:49 -
Why is my converted video stretched beyond the viewing area on my TV?
By Clare in forum Video ConversionReplies: 2Last Post: 6th Oct 2007, 14:41 -
Original video got replaced by random video
By Jn183 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 11:19 -
Help with rendering time-stretched video
By architectus in forum EditingReplies: 1Last Post: 26th Jul 2007, 15:34
