  1. I'm creating a simple VCD from an .avi file using the presets for SVCDmpeg2enc but the final result outputs the letterbox video off-centered vertically. The top is right at the top edge of the screen and there's one huge black bar along the bottom, basically shifting the whole video up to the edge. I have had this happen once before but i don't know if a setting is off or if it's in the .avi file. And if it is the .avi file - is there a way to fix that?? They look fine playing through Quicktime and VLC but not on the dvd player. I appreciate the help!
    moving your to our macos section.
    Jul 2003
    at home
    I reckon ffmpegX has automatic adjustment for the problem. Give it a try. I haven't done SVCDs for quite while.
    Go to http://homepage.mac.com/major4/index.html and ask your question in the forum there.
    Cheers,
    JoachimS
  4. Originally Posted by JoachimS
    Cheers,
    JoachimS
    Thanks, but that site directed me to this forum.
    Jul 2003
    at home
    Is it possible to download the AVI movie from somewhere?
  6. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    ffmpegX has it's own forum on this site.
