    Apr 2005
    Florida
    Whenever I capture with Windv, it breaks my projects in "pieces". I captured a 120 minute video and it cut it into 11 files. How can I change the amount of files the video gets cut into.
    USA
    Take a look at this thread. https://www.videohelp.com/forum/viewtopic.php?t=267339&highlight=windv
    If you want further info, do a forum search for 'WinDV' and you will find the answers. Also if you 'hover' your mouse over the preferences in WinDV, you should see some help there.
