i have a sony mini dv camcorder. i use ulead video studio to capture footage using firewire cable,but....
after capturing footage from the camcorder and playing it back, i can see some tiny horizontal lines in the picture.
example: i filmed my hand moving in front of the camera, playing it back on the unit itself the image was good,but after i captured it to my pc i could see smal horizontal lines around the edges of my hand when i was moving it.
what is causing this?
any ideas
thanks
Hi ricardouk,
This is normal when playing interlaced footage (as yours will be from a miniDV cam) on a PC monitor, which displays a progressive image.
It's quite a lot to go into what they are and how they differ (interlace vs progressive) - some reading for you.
If you have WinDVD or PowerDVD, play the footage on there and you'll see it's OK - these take the interlace into account and play as progressive on a PC monitor, hebce why it'll look OK.
You're OK to use the AVIs in Ulead for editing etc.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
thanks daamon
i was playing the footage using wmp10 and i tryed powerdvd and the artifacts dont show up
thanks.
one last question
im capturing straight to dvd is this the best way to do it?
or should i capture to another format and then to dvd?
is it ok to burn interlaced footage to view on a normal tv -
Originally Posted by ricardouk
If you want to edit your DV material, or if you want best quality it is best to capture to DV format, then edit, then encode in a second pass. I recommend this for home movies.
For lesser captures (like TV material) that won't be edited or lightly edited where perfect frame accuracy is less important, then direct capture to DVD Mpeg2 is OK. -
No problem, and edDV couldn't have worded the answer to your second questions any better...
Carpe diem.
Thanks you guys!
Should i keep ulead video studio or is any program outhere better?
i have tried virtualdub to capture it to avi but but it fils my hard drive after a while of capturing
thanks -
mpeg2 -> x264 image issues (artifacts in dark areas)
By honelnik in forum Video ConversionReplies: 12Last Post: 29th Apr 2012, 11:13 -
Media Player Classic - image capturing
By terrypin in forum Newbie / General discussionsReplies: 7Last Post: 17th Aug 2010, 14:07 -
Capturing a still image from video in Sony Vegas 8.0 Pro
By ruffryd in forum EditingReplies: 2Last Post: 29th Oct 2008, 16:49 -
Getting artifacts and dropped frames capturing DV
By CleanRich in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 16Last Post: 1st Nov 2007, 19:54 -
1st Time Capturing - No Image - Aver EZMaker USB
By kmxe in forum Newbie / General discussionsReplies: 12Last Post: 13th Oct 2007, 09:43
