I have this mkv file that contains 5.1 aac audio. VLC plays it fine but it seems impossible to convert it. The video track converts fine, but the audio fails. ffmpeg says it can't resample anything with more than 2 tracks. mencoder does something, but then produces an error and the resulting (unfinished) new audio is unusable, kind of strange slo-mo ghostly sounding.
If I extract the audio with mkvextract, it says 'A_AAC/MPEG4/LC/SBR' as codecID. The resulting "raw" .aac file plays fine in VLC and RealPlayer 10, but ffmpegX won't recognize it.
So is there any way to convert the 5.1 aac sound to AC3 with ffmpegX (or any other share- or freeware tool)?
OK, here's a workaround for this problem:
You need mkvextract to demux the mkv. Also you need FAAD 2 for Mac. In the terminal demux the movie like this:
mkvextract tracks movie.mkv 1:movie.divx 2:audio1.aac 3:audio2.aac 4ubs.srt
Than convert the raw aac files in the terminal with FAAD with the -d option to convert 5.1 to 2 channel:
FAAD_OSX -d audio1.aac
resulting in a audio1.wav file that can be converted easyly to mp3 with ffmpegx, Audacity or iTunes.
Then mux the movie.divx and the audio.mp3 to an avi in ffmpegx and the resulting avi can be converted to DVD (or any other format) also using the extracted subtitle file.
Originally Posted by BeardFan
I'll be using this fairly often. Thanks.
But now I've encountered a new problem. The divx inside the mkv is slightly messed up with the framerates. ffmepgx says it's 25 fps inside the mkv, but the extracted movie wrongly says NTSC framerate (thus being much shorter). And when you calculate the framerates by dividing the actual frames by the supposed running time you get something weird like 24,1005 (no! it's not NTSC film, then the movie would be too long). So I forced the calculated framerate into the avi header, resulting in the same duration as the audio, but still the muxed avi has a slight desynch.
Which leaves the conclusion that mkv might be a nice container in theory, but in the real life, where I want to play the movies on my divx capable standalone, mkv is utter crap!
So is there a tool to force-synch the video and audio to exactly the same duration?
Quicktime Pro with its "add scaled" command might work. Don't forget to add the video to the audio and not the other way around.
(Mp4, AACv2, MKV, Webm, Theora) Drag Drop Convert GUI Update v 1.2.0.0
By richter03 in forum Video ConversionReplies: 11Last Post: 21st Apr 2013, 05:35 -
How to convert .mkv movies aac or mp4a soundtrack to mp3 ?
By winter snake in forum Video ConversionReplies: 16Last Post: 11th Feb 2013, 17:38 -
MKV AAC GUI Converter with Nero AAC Codec
By prijatelj.v in forum AudioReplies: 4Last Post: 26th Mar 2012, 08:41 -
How to convert a AAC audio file in a mkv file to AC3?
By wolvie77 in forum AudioReplies: 4Last Post: 13th Mar 2012, 21:59 -
Convert AAC 6ch to AAC 2ch w/ Dolby Pro Logic II Surround info
By SiegeX in forum AudioReplies: 5Last Post: 28th Dec 2009, 16:58
