This tool give more in-depth information about AVI files.
This is a BETA version. Once "finished" this tool will be integrated into VideoInspector.
Download: ftp://ftp2.kcsoftwares.com/kcsoftwa/beta/...rateGrapher.zip
Feedback, comments and bugs report would be greatly appreciated !
Results 1 to 11 of 11
KC Softwares
http://www.kcsoftwares.com -
bitrate? I get very high values(up to 250 000) in the left bar if I open some divx or xvid.
It draws Frame size (in byte). I'll convert to bitrate in a next version.
KC Softwares
If you have more suggestions or comments... i would greatly appreciate some feedback about this app written in 3 hours before I include it into VideoInspector ...
Thanks !KC Softwares
FourCC is available in VideoInspector.
AViBitrateGrapher will be a "plug-in" for VideoInspector soon.KC Softwares
yes - zoom in and/or cursor postion readout at that location (where you put your cursor) , along with the frame count at the position (or TC) ..
nice thing - thanks"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Zoom already work : click and drag to the bottom right to zoom in, top left to zoom out
KC Softwares
ahh ok - thanks
You're welcome !
Thanks for trying this app !KC Softwares
Converting AVI Audio Bitrate
By RayArt in forum Video ConversionReplies: 3Last Post: 13th Sep 2009, 08:33 -
DV AVI -> H 264 (bitrate and other settings)
By xprezons in forum DVD RippingReplies: 13Last Post: 31st Aug 2009, 02:13 -
AVI to MPG: Optimum bitrate?
By NDMMackay in forum Video ConversionReplies: 10Last Post: 12th Oct 2008, 10:03 -
Changing AVI Bitrate!
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 5Last Post: 8th May 2008, 11:23 -
recommended bitrate for dvd to avi
By blarson in forum DVD RippingReplies: 4Last Post: 10th Jan 2008, 11:17
