Hi
I am capturing with USB Instant DVD from VHS tape for SVCD burning and the video is out of synchronization woth the sound. Any ideas? The video comes first and then the sound. Video and audion quality is good.
Regards
Stelios Christofides
Do you have the latest CapWiz program? If not, get it from the ADS website. It will allow you to adjust the audio/video timing.
Hi
Thanks for youe reply. Yes I do have the latest Capture Wizard. I did try the settings with the Video/Audio Delay sliders but no luck.The audio is about 2 seconds delayed.
Regards
Stelios -
I only dream in black & white...
MSN: paschendale@gmail.com -
I, too, have been getting inconsistent results with audio sync when capturing from VHS videotapes...it can be right on, a little off, or very off (always audio first, then video).
I have updated all the software and drivers from ADS.
My system is an HP Pavilion PC, 800 MHz Pentium III, 1280 Mb RAM, 45 GB HD, Windows Me.
Although I'm sure that suggested procedure for fixing sync with TMPGEnc and GoldWave works, I would like to be able to capture in-sync from the outset. Any suggestions?
Thanks, Bruce -
I'm also in same boat using the ADS USB, Instant DVD.
I'm also getting video and sound out of sync.
I havent tried the Ulead software bundled with the device, from what i seen, its a very striped down version of whats available for demo at Ulead.com. Tonight if i get time i will re-test using the Instant DVD device and see if i get things in a bit more sync.
3d video with dts sound how to convert to ac3 sound
By fredddiemercury in forum Video ConversionReplies: 4Last Post: 2nd Nov 2011, 14:54 -
Video has sound ONLY when ... Why???
By ericdunn in forum Newbie / General discussionsReplies: 10Last Post: 10th Dec 2010, 23:41 -
Need advice getting rid of buzz sound at end of every word of video sound
By OM2 in forum AudioReplies: 18Last Post: 30th Oct 2010, 11:58 -
MT2S files play video in MPC but no sound+Ultra Cyberdvd wont display video
By btvs2000 in forum Software PlayingReplies: 7Last Post: 22nd Sep 2008, 15:44 -
no video but sound playing video with MPC
By majax79 in forum Software PlayingReplies: 5Last Post: 30th Mar 2008, 03:05
