I know each tv can be set to diff. contrasts/brightnesses themselves, but there was such a large difference in c &b from tv to tv, that I thought maybe there was something else I could do in editing (using premiere 6)
isn't there a way to make the brightness/contrast the way you want it NO MATTER what individual televiision you use? Or at least lessen the diff?
Upgrade to Premiere Pro, use the waveform monitor and match video levels to the SMPTE colorbar. DV and DVD use 0 IRE for black (digital level 16) and 100 IRE for white (digital level 235). The colorbar is used to calibrate the TV monitor.Originally Posted by Marley_
No rocket science here, just quality control. -
Is there a cheaper way to accomplish the same thing?Upgrade to Premiere Pro, use the waveform monitor and match video levels to the SMPTE colorbar. DV and DVD use 0 IRE for black (digital level 16) and 100 IRE for white (digital level 235). The colorbar is used to calibrate the TV monitor.
Using Premiere 6 you can try to eyeball levels vs. the colorbar levels.Originally Posted by Marley_
First thing to do is set your TV to a proper color bar. I posted some for download here (near end of thread). Just copy the jpg to your Premiere timeline.
https://www.videohelp.com/forum/viewtopic.php?t=259098&start=60
Instructions
http://www.indianapolisfilm.net/article.php?story=20040117004721902
http://www.videouniversity.com/tvbars2.htm
If you are in NTSC territory and are using your DV camcorder for preview, remember that your TV must be set to 0 IRE black while DV editing. Return it to 7.5 IRE black for watching the DVD and normal TV.
Easiest way to do that is to encode a DV color bar on your DVD. When you play it back from the DVD player it will have 7.5 IRE setup. Adjust your TV brightness to that.
For normal DVD/TV watching you can also use the THX test pattern found on many commercial DVD to adjust your set.
http://www.thx.com/mod/products/dvd/optimizerIntro.html
what program should i use to make some menus with diff chapters?
By shadowofanubis6 in forum Authoring (DVD)Replies: 3Last Post: 1st Mar 2010, 00:48 -
Do you see any diff betw default in HD and full HD on YouTube?
By brassplyer in forum Video Streaming DownloadingReplies: 9Last Post: 10th Feb 2010, 14:44 -
VCRs - Multisystem vs Multiconverter - Whats the diff?
By quantass in forum Newbie / General discussionsReplies: 4Last Post: 21st Dec 2008, 18:15 -
ac3/mpeg same on PC, diff. on TV
By spiritgumm in forum Newbie / General discussionsReplies: 9Last Post: 31st May 2008, 08:39 -
Diff languages in Star Wars conversion.
By neomaine in forum DVD RippingReplies: 0Last Post: 5th Feb 2008, 09:06
