Hello...
I am trying to figure out this annoying problem I am having with Quicktime pro 6. Basically I have a .mov file with a 3ivx 4.5 video track and I am trying to add an audio track right on it from an aiff file, and what happen was it was pasted onto it but wherever the audio is, the video is white!! no video! So I then tried converting the aiff to mp3, still the same problem.
How can I add this audio track successfully to my file? Thanks.
Select the video file in Quicktime 6 Pro.
Open the AIFF file you want to use.
Click back on the video File,
perform a select all ( cmd-A).
then perform a copy(cmd-c).
now, select the Aiff file.
perform a select all (cmd-a).
then under the Edit menu, choose
Edit-->Add Scaled.
The video will now be properly added to the Audio,
and unless there is something that you're not telling us
about bitrate or codec, it should now play fine,
once you do a Save As--> Self Contained QT .mov ( movie)
file...."Everyone has to learn, so that they can one day teach."
When I'm not here, Where can I be found?
Urban Mac User
please recommend tool for editing + adding audio track to video
By lovelove in forum Newbie / General discussionsReplies: 4Last Post: 25th Sep 2011, 23:10 -
Adding a second audio track to a DVD-R
By danielmak in forum MacReplies: 1Last Post: 30th May 2010, 21:31 -
Adding A Second Audio Track
By DeathStalker77 in forum Authoring (DVD)Replies: 0Last Post: 11th Aug 2009, 01:16 -
Adding an Audio/Music Clip into the main Audio Track?
By Moontrash in forum EditingReplies: 3Last Post: 20th Nov 2007, 17:45 -
Adding another audio track to avi
By mk15 in forum AudioReplies: 1Last Post: 24th May 2007, 10:33
