i understand it has a mpeg2 trial for 30 days , but i would like to re-encode svcd to dvd, 3 total files, so i guess i would have to jhoin them 1st then encode, right? i used this program before and i had to make a seperate audio file, is that still the case, and if what other app. do i use for that? also how well are the filters? my end result will be a mpeg2 file or vobs? so if its mpeg2 i then need to author a dvd as well. i always try to keep it simple, i do understand some of the process just never do this much to make it stick. thanks
you can try make a dvdsvcd using svcd2dvd or dvd-lab.
or reencode with vso divxtodvd...easiest!
problem with tmpgenc author 4 trying to re encode
By kingsley in forum Authoring (Blu-ray)Replies: 1Last Post: 19th May 2012, 17:28 -
Does reauthoring (TMPGEnc DVD Author) re-encode / degrade video quality?
By MheAd in forum Authoring (DVD)Replies: 8Last Post: 9th Aug 2010, 05:42 -
How to encode using TMPGEnc Xpress to 264?
By klas in forum Video ConversionReplies: 1Last Post: 8th Jul 2008, 04:13 -
How to batch encode with TMPGEnc
By BonnieW88 in forum Video ConversionReplies: 8Last Post: 20th Feb 2008, 20:52 -
TMPGEnc DVD Author - Does it re-encode DVD Video?
By bbanderic in forum Authoring (DVD)Replies: 2Last Post: 21st Oct 2007, 12:58
