I had a poor experience with a LiteOn 5005 that I ended up returning to Costo. I am thinking of picking up the iLo DVDR04 at that $119 mark from Walmart and trying to give it another go.
Of the two local Walmarts, I have a selection of units that were made either Aug 04 or Dec 04. Does it matter? I know the later ones may have a faster burner, but without a HD, it would be real time anyway so that's moot. I read the LiteOn had a firmware issue with new units not being able to go backwards? Does the iLo have any similar quirks? Or should I just grab a box and not look?
Well, let me just add this: I have had three units, in roughly three months. The first two were made July 2004. THIS one was, I think October 2004, and I have NOT had the problems with it, like I did with the others. This last time, I INTENTIONALLY picked the "newest" one they had on the shelves. Coincidence? I don't know. Now, this one HAS given me the same grief that the other two did: Not recognizing it's own burnt discs. However, it was only one time that it has done that....................................so far, that is......
you do know that ilo is a rabadged liteon right? I have both, they work exactly the same, same menus, same quality and problems. Its just the ilo doesnt record to cds and no support for dash media.
walmart sells the ilo dvd05 now, which is a rebadged cyberhome, which i hear is worse than ilo/liteon -
Yes I know it's a LiteOn. My problem was a bad unit I suspect. I'm going to try again, especially since the price dropped on the iLo. As long as it provides the basics without too much trouble, I'll consider it disposable.
Set "Output filename" As Default Global "File/segment title" In MkvMerge?
By LouieChuckyMerry in forum Video ConversionReplies: 0Last Post: 9th Jul 2011, 01:52 -
WMV files: Changing "Recorded Date", "Media Created" fields in metadata
By axhack in forum EditingReplies: 5Last Post: 18th Sep 2010, 01:27 -
"stretching" or "cramming" aspect ratio when I convert .avi to MP4
By Agent Bauer in forum ffmpegX general discussionReplies: 3Last Post: 21st Mar 2010, 10:30 -
Editorial: Why "HD DVD" Is Thumping "Blu-ray Disc"
By Specialist in forum Latest Video NewsReplies: 146Last Post: 16th Feb 2008, 08:08 -
Review "HYFAI" MP3/MP4 "Nano" clone from ebay
By NG in forum Portable VideoReplies: 29Last Post: 18th Sep 2007, 05:45
