Does anyone know if it's possible to specify chapter points with a great accuracy than 1 second with DVD author? It appears to just take HH:MM:SS.
You won't get any better than I-frame accuracy, which is generally every 12-15 frames unless an I-frame has been specified for the start of a scene. So with accuracy down to the second you will be only half a second off anyways.
I don't use it myself, but a quick read of the docs for DVD Author and DVD AuthorGUI shows accuracy only the second, which would imply nearest I-frame following the specified second.
GUI for DVD Author talks about it's extended chapter editor, which allows for fractions of seconds. This might be what you need to look at. It looks like it can be downloaded as a seperate standalone if you do your own scripting. You can read about it here https://www.videohelp.com/~gfd/ChapEditGFD_eng.htmRead my blog here.
Thanks. Hadn't thought of the I frame thing, which does make sense. I'll check out that tool.
Shifting Chapter Point on DVD without reauthoring
By Instant Martian in forum DVD RippingReplies: 4Last Post: 4th Sep 2009, 11:10 -
GUI for dvdauthor - How to make chapter thumbnails run the chapter video
By deco81 in forum Authoring (DVD)Replies: 4Last Post: 15th Dec 2008, 12:51 -
Placing a chapter point at layer break spot?
By sdsumike619 in forum Authoring (DVD)Replies: 0Last Post: 12th Aug 2008, 20:02 -
dvdauthor problem "chapter doesn't exist"
By ecc in forum Authoring (DVD)Replies: 2Last Post: 28th Jan 2008, 09:54 -
Automatic DVD Chapter Point Insertion
By cw4u in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2007, 01:43
