hi i was just wondering if there is a way for me to convert quicktime to any format that can be put to a dvd disc ?
I use DVD lab pro to make DVD, so here's what i do...
convert the mov to MPEG2 file using TMPGEnc plus (quicktime plugin installed)
then use the MPEG2 file into DVD lab Pro (I think it's the only format that DVDlab accepts)
I hope that helps.play dead -
Or for an even easier method, you can try VSO DivXToDVD. It says it can convert MOV (Quicktime) to DVD. There are other methods in the 'CONVERT' guides to the left. <<<<<
Well assuming that it does use libavformat/codec for input, libavformat does indeed support passing mov files, however libavcodec doesn't support decoding all possible quicktime streams.
Choppy Video- Hard to watch in Quick Time
By RS4425 in forum MacReplies: 5Last Post: 1st Sep 2010, 16:03 -
converting Quick Time
By butterflies in forum Video ConversionReplies: 12Last Post: 4th Dec 2009, 09:36 -
Quick time reference (.mov) also readable with WMP?!
By B-Twien Bytes in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2009, 12:37 -
Quick Time Pro Help
By Soccerman77 in forum Video ConversionReplies: 1Last Post: 14th Dec 2007, 11:38 -
Quick Time Failure, HELP
By jackboyko in forum ffmpegX general discussionReplies: 1Last Post: 25th May 2007, 14:41
