I have been burning DVDs about 2 weeks now. I have a problem(s) with my Rosewill RD-162 DVD burner.
Here is my backup process:
1. smartripper
2. vobblanker
3. dvdshrink
4. nero express
I have a DVD player I rip from and for some reason two stealth drives listed, I think one of them is because I use daemon tools to verify an .ISO file I create with dvdshrink. After making this file, I test with daemon to be sure the DVD is compliant, then I use Nero to COPY DISK from the daemon drive. I am using Maxell DVD +R for my standalone and +RW for testing as well. This has worked fine till now.
The problem now is that almost every burn I do results in either an “unspecified target error” or a successful burn which will not play on my standalone (says NO PLAY) and when I then try to look at it on the DVD player on my PC, it says no disk in the drive.
If I get the “unspecified target error” Nero will show the disk as empty, but will no longer do anything with them, they go to the coaster pile. The “no plays” are going there as well.
I have tried outputting from dvdshrink as a file, as an .ISO, and directly to Nero. None seem to work now. I have removed and reinstalled Nero, I have removed all CD/DVD/stealth drives and rebooted to find them all reinstalled.
Also, my drives have now become out of order, I don’t know if that has anything to do with it. They were in the following order:
1. E – DVD burner
2. F – DVD player
3. G – stealth drive (Nero?)
4. H – daemon mounted drive
Now they are:
1. E - DVD player
2. F - DVD burner
I've also made about 5 RW coasters that Nero won't read after it finishes writing them. Then it will never recognise them again, but I tried again with a +RW which worked and plays on my PC, so I tried another +R and failed with the following log if it makes sense to anyone here:
1A20-0202-0330-1727-0458-7779
Windows XP 5.1
IA32
WinAspi: File 'Wnaspi32.dll': Ver=2.0.1.45, size=172099 bytes, created 6/27/2004 8:42:16 PM
ahead WinASPI: File 'C:\Program Files\Ahead\nero\Wnaspi32.dll': Ver=2.0.1.68, size=160016 bytes, created 7/22/2004 4:33:44 PM
Nero version: 6.3.1.26 (Nero Express)
Recorder: < 16X8 DVD DUAL> Version: A070 - HA 1 TA 0 - 6.3.1.26
Adapter driver: <atapi> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ATAPI
CD-ROM: <IDE DVD-ROM 16X >Version: 3.10 - HA 1 TA 1 - 6.3.1.26
=== Scsi-Device-Map ===
DiskPeripheral : IC35L060AVV207-0 atapi Port 0 ID 0 DMA: On
DiskPeripheral : ST360020A atapi Port 0 ID 1 DMA: On
CdRomPeripheral : 16X8 DVD DUAL atapi Port 1 ID 0 DMA: On
CdRomPeripheral : IDE DVD-ROM 16X atapi Port 1 ID 1 DMA: On
CdRomPeripheral : NERO IMAGEDRIVE 1.0f Imagedrv Port 2 ID 0 DMA: Off
CdRomPeripheral : Generic STEALTH DVD st3mp28 Port 3 ID 0 DMA: Off
=== CDRom-Device-Map ===
16X8 DVD DUAL F: CDRom5
IDE DVD-ROM 16X E: CDRom7
NERO IMAGEDRIVE G: CDRom11
Generic STEALTH DVD H: CDRom9
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 74448896 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 511MB (523760kB)
Free physical memory: 214MB (219492kB)
Memory in use : 58 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
20.5.2005
UDF/ISO compilation
5:57:00 AM #1 Phase 112 File dlgbrnst.cpp, Line 1855
DVD-Video files reallocation started
5:57:00 AM #2 Phase 114 File dlgbrnst.cpp, Line 1855
DVD-Video files reallocation completed (no file modified)
5:57:00 AM #3 Text 0 File Isodoc.cpp, Line 6083
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
5:57:00 AM #4 Phase 111 File dlgbrnst.cpp, Line 1855
DVD-Video files sorted
5:57:00 AM #5 Text 0 File Reader.cpp, Line 126
Reader running
5:57:00 AM #6 Text 0 File Writer.cpp, Line 124
Writer 16X8 DVD DUAL running
5:57:00 AM #7 ISO9660GEN -11 File geniso.cpp, Line 3899
First writeable address = 0 (0x00000000)
5:57:00 AM #8 ISO9660GEN -11 File geniso.cpp, Line 3899
5:57:00 AM #9 Text 0 File Burncd.cpp, Line 3152
Turn on Disc-at-once, using DVD media
5:57:00 AM #10 Text 0 File DlgWaitCD.cpp, Line 247
Last possible write address on media: 2295103 (510:01.28, 4482MB)
Last address to be written: 2286127 (508:01.52, 4465MB)
5:57:00 AM #11 Text 0 File DlgWaitCD.cpp, Line 259
Write in overburning mode: NO (enabled: CD)
5:57:01 AM #12 Text 0 File DlgWaitCD.cpp, Line 2162
Recorder: 16X8 DVD DUAL, Media type: DVD+R
5:57:01 AM #13 Text 0 File DlgWaitCD.cpp, Line 420
>>> Protocol of DlgWaitCD activities: <<<
5:57:01 AM #14 Text 0 File ThreadedTransferInterface.cpp, Line 813
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2286128 (2286128) = #2286128/508:1.53
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2286128 blocks [ 16X8 DVD DUAL ]
5:57:01 AM #15 Text 0 File ThreadedTransferInterface.cpp, Line 984
Prepare recorder [ 16X8 DVD DUAL ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4681990144, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2286128 | lead-out | 1 | 0x00 | 0x41
5:57:01 AM #16 Phase 24 File dlgbrnst.cpp, Line 1855
Caching of files started
5:57:01 AM #17 Text 0 File Burncd.cpp, Line 4163
Cache writing successful.
5:57:01 AM #18 Phase 25 File dlgbrnst.cpp, Line 1855
Caching of files completed
5:57:01 AM #19 Phase 36 File dlgbrnst.cpp, Line 1855
Burn process started at 8x (11,080 KB/s)
5:57:01 AM #20 Text 0 File ThreadedTransferInterface.cpp, Line 2344
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
5:57:01 AM #21 SCSI -1066 File Cdrdrv.cpp, Line 1191
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x03105000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x24
Sense Qual: 0x00
CDB Data: 0xAD 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x08 0x04 0x00 0x00
Sense Data: 0x70 0x00 0x05 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x24 0x00
5:57:01 AM #22 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 7:11,336 (431336ms) -> OK
5:57:01 AM #23 Text 0 File DVDPlusRW.cpp, Line 628
Start write address at LBA 0
DVD high compatibility mode: Yes
5:58:23 AM #24 SCSI -1135 File Cdrdrv.cpp, Line 1445
SCSI Exec, HA 1, TA 0, LUN 0, buffer 0x09D90000
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x0C
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x01 0x30 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x03 0x00 0x01 0x2E 0x10 0x0E
0x00 0x00 0x00 0x00 0x0C 0x00
5:58:23 AM #25 CDR -1135 File Writer.cpp, Line 304
Write error
5:58:23 AM #26 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
5:58:23 AM #27 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
5:58:31 AM #28 Phase 127 File dlgbrnst.cpp, Line 1855
Generating DVD high compatibility borders
5:59:17 AM #29 SCSI -400 File Cdrdrv.cpp, Line 1191
Sense Key: 0x04 (KEY_HARDWARE_ERROR)
Sense Code: 0x91
Sense Qual: 0x25
CDB Data: 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x00
Sense Data: 0x71 0x00 0x04 0x00 0x00 0x00 0x00 0x0E
0x00 0x00 0x00 0x00 0x91 0x25
5:59:17 AM #30 Text 0 File dlgbrnst.cpp, Line 1713
Set remaining time: 0:00,000 (0ms) -> OK
5:59:17 AM #31 Phase 129 File dlgbrnst.cpp, Line 1855
Generating DVD borders completed successfully
5:59:17 AM #32 Text 0 File dlgbrnst.cpp, Line 1713
5:59:17 AM #33 Phase 38 File dlgbrnst.cpp, Line 1855
Burn process failed at 8x (11,080 KB/s)
Existing drivers:
File 'Drivers\CDRALW2K.SYS': Ver=5.10 (117), size=23593 bytes, created 6/29/2004 9:58:54 PM
File 'Drivers\ASPI32.SYS': Ver=4.71 (0001), size=17005 bytes, created 5/6/2002 11:01:08 AM
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 8/29/2002 1:27:50 AM (Adapter driver for rec)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Results 1 to 19 of 19
Why not just use DVD DECRYPTER to rip then use DVD SHRINK to ISO IMAGE and then burn with DECRYPTER? Seems a easier process then what you have posted unless you're creating your own DVD's with video footage from a digital camcorder or something.
First, cause I dont have it, second cause I dont know if it blanks VOB files, third, I said I AM using DVD SHRINK to create ISO files. I did not mention, however, that it has started creating .MDS or .MDO files in stead if the .ISO files I told it to make. These will NOT write on my system and could be part of the problem, but I cannot make it write .ISO files any more.[/i]
Madwand...you cant make a 4gb+ sized .iso file on a drive that's fat32, it must be NTSC.. Is your drive setup for NTSC?
:star: :star: :star: :star:
Archived DVD Scans
Nero V ImgTools V Decrypter
:star: :star: :star: :star: -
then why was it originally making .ISO files, now it does not? It was working fine when I had .ISO files to work with. Now I cannot get it to make .ISO files.
anyway, that answer has not helped me. I still have the problem I described, regardless of ISO or MDS. -
it makes .MDS and .ISO files
you should have a Movie.MDS and Movie.ISO -
No, there are no .ISO files, only .MDS and variations of that. The other times it wrked it was .ISO files and variations of ISO.
And to Fandim, I'm not trying to make 4gb+ sized files, the times it was working, it made seperate smaller files and worked fine. -
I yanked the burner and returned it and got a Sony and it works fine now. anyone reading this, I would't give much credence to any of the responders listed above, they obviously have less of a clue than I had.
don't mind Madwand1, he's upset, he just found out his state doesn't allow same sex marriages.
member since 1843 -
Originally Posted by Madwand1
Madwand1 wrote
I yanked the burner and returned it and got a Sony and it works fine now. anyone reading this, I would't give much credence to any of the responders listed above, they obviously have less of a clue than I had. -
It works and cost less than the other one, so I am ahead. Getting no answers can't be any worse than the useless replies I got here. 4G file limits, fat32, .ISO...all useless.
Many will have different versions as to why things may have gone wrong with your PC's burner. My own experience would have led me to make a completely different suggestion that SP2 may be at fault. Probably another 'useless' answer to you, but in another instance it would have been helpful.
Personally, if I post a question and someone is nice enough to take the time to respond and attempt to help, I am very grateful, whether it actually solves the issue or not.Cole -
Did you look at your log? A minute twenty-two into the burn, there was a medium error. How many discs did you burn with that drive and how many in a row? I've seen this message on drives that were dead. These aren't industrial burners, lasers have a limited lifetime i.e. they need a cool down period between burns.
That's the answer I was looking for. That's why I submitted the log, I don't have any idea what that stuff meant. I was hoping someone else did. But I only burned about 15 disks with it in the week I had it when I printed that error msg. Your answer would have told me that the drive was defective. Thanks.
Madwand1,
I'm not so sure that dvd 'backing up' is an 'exact science' which is why you got replies that didn't satisfy you. They were made by people willing to make suggestions to you that may have helped you.
I'm curious about your backup method - why do you need to use vobblanker? Why do you even need to use DVDripper. I usually just DVDshrink straight from original DVD to HD. -
I take exception to certain answers given where no thought has been given to the question, such as the reference to 4G file limits. Why would someone give that as a solution to disk errors, especially when it was in no way referenced in the question? I have never seen a 4G video file in years of ripping DVDs. Another would be the questioning of my methods, when the method I have described is almost verbatim from one of the guides on this site, with the exception being that I use smartripper first, as a carryover from my SVCD days. Answers like that merely detract from the original question and any possible valid answers. I have no problem with people trying to help, but if you don't know the answer, I'd rather wait to hear from someone who does.
I use SMARTripper to rip it. I could rip using vobblanker, I guess, but I don't trust it. I use vobblanker to remove wasteful huge amounts of unwanted data to eliminate the need for unnecessary compression. dvdshrink does not allow this, but it does allow for the elimination of massive amounts of unwanted sound files. The three together give me the most efficient use of space.
WinDV used to work fine ! But not working now
By vatsyk in forum Capturing and VCRReplies: 2Last Post: 8th Mar 2010, 05:43 -
DVD playback fine on computers, but not so fine on home players...
By stonesfan in forum Authoring (DVD)Replies: 2Last Post: 15th Nov 2009, 17:03 -
Video8 to DV, working fine except for one odd slightly mysterious tape
By DSMcCoy in forum RestorationReplies: 8Last Post: 13th Apr 2009, 22:35 -
Ulead DVD Movie Factory won't burn DVDs after had been working fine
By alh132 in forum Authoring (DVD)Replies: 4Last Post: 12th Mar 2009, 15:47 -
Windows Media Player 11...No Video but Sound?? It was working fine
By sandman423 in forum Software PlayingReplies: 2Last Post: 14th Jan 2008, 13:57
