i used vso divx to dvd to burn some vidoe clips i made on my comp to dvd format then used dvd shrink 3.2 to burn it to a dvd when i tried to play this it scrolled up the whole time and it was unwatchable is thier any thing i can to fix this.
i am not sure of the source information i cant find it in the properties and the divx to dvd settings i am not sure of either as when i open the program i dont have any options except source destination and then convert or i can check to have it burn for me i did not. my dvd player is not multi format but my dvd burner is a multi layer not sure if that helps.
ok i am retrying the conversion and it says the frame rate is 23976/1000 and it doesnt matcxh the output frame rate of 29.97fps rate compensation will be used. and it choose ntsc as an out put(mpeg2video 720x480, 29.97 fps q=2-31, 7013kb/s) as output stream that is what i got from it this tiem hope it helps
VSO Media Player - report - doesn't play anything
By Jeremiah58 in forum Software PlayingReplies: 1Last Post: 19th Aug 2011, 04:39 -
VSO ConvertXtoDVD is turning 155 mins into 95
By Calavera33 in forum Video ConversionReplies: 7Last Post: 25th Apr 2011, 12:32 -
VSO Blu-ray to DVD
By Bonie81 in forum Newbie / General discussionsReplies: 0Last Post: 20th Jan 2011, 13:40 -
Slower encoding with VSO than it used to be
By Brainstorming in forum Video ConversionReplies: 8Last Post: 28th Dec 2010, 21:52 -
pc crashes with vso convertx
By dvdex in forum Newbie / General discussionsReplies: 2Last Post: 12th Oct 2009, 19:40
