    Mar 2005
    Toronto
    Hi, I have hopefully a simple query about MTR. Is there a method through The Ripper to extract the Main Feature, and movie extras while NOT extracting the previews and commercials they insultingly place in DVDs?
    Thanks!
    Jan 2005
    Internet
    Read the PDF that came with the MTR.
    Mark V
    10.4.10 OS X 1.25GHz G4 768MB DDR SRAM Pioneer DVR-106D and external DVR-111D
    Mar 2005
    Toronto
    Thanks for the RTFM response, but if the PDF covered this I wouldn't have asked the question here. I took out the previews using MTR, but it also removed the Extras. There is no documented way to take out one while leaving the other.
    Jan 2005
    Internet
    Then i dont think it can be done.
    I always say read the PDF because nobody says they read the PDF that comes with MTR when they usually ask questions and that is always the first place to look.
    Mark V
  5. Member terryj's Avatar
    N35°25.24068, W097°34.204
    do a disc copy in MTR.
    then do the Cell extraction in DVD2ONEX.
    MTR, AFAIK, doesn not do Cell Extraction(?)
    ( i'm sure if it does GB or WW will correct me.)
    But I have always done cell extraction in DVD2ONEX,
    after the rip outpput from MTR.
    Using Cell Extraction, you can then select the main feature,
    and any secondary features, and then format
    this to VIDEO_TS, then burn in Toast.
    "Everyone has to learn, so that they can one day teach."
    When I'm not here, Where can I be found?
    Urban Mac User
    Sep 2003
    San Pedro, CA
    terryj -
    since there's no preview window in DVD2ONEX, what's you're method for choosing the correct cells to extract?
  7. One way I use is Yade, which does have a preview window. I make note of the cells I want then select thoses in DVD2ONE leaving the rest unchecked. So far so good.
    T
    I have also used the join feature in DVD2ONE and tacked any extras on the end of the movie. This might be easier!!
  8. Member terryj's Avatar
    G13--
    length of duration for main movie,
    then playing the DVD in VLC will ususally
    tell me/give me a hint of what extras I want
    by their chapters #.
    http://www.dvd2one.com/osxtoast.php
    Urban Mac User
