I was tinkering around with ways I could lighten the load for my hard drive, and I figured I could burn a bunch of my .avi files onto a couple of DVD's(and make them playable in DVD players). DVD Lab came bundled with my DVD Writer so I have the means to make a nice organized menu and even have chapter points, etc.
The problem however is converting those AVI's to MPEG form so they 1) have no loss of quality and 2) will be streams that will be recognized by a DVD player. I have used AVI2DVD and CuCuSoft Video Converter and they have done the job, but not well. There is a MAJOR loss of quality from the original( blocky picture and sometimes the screen jiggles), but that was because I converted them to SVCD and I read that you will have lots of degredation in quality if you convert an AVI to MPEG. I read the proper tutorials on how to use those programs and select the right options so that the end product should match the original but have had no luck.
My question is, in order to get the full quality of the movie do I have to convert the AVI file to DVD format? If so does that mean I can only burn one movie to a DVD5 and what is the BEST program for AVI to DVD conversion?
If you want to play them on a settop DVD player, yes, you have to convert them to MPEG-2.
For the best quality, it's all in the encoder settings. I use TMPGEnc encoder and author. Both have a trial version.
The files, if they are, say DIVX or XVID, will become much larger. Typically a 700MB file will be 1.5G or larger, depending on the encoder settings.
If you have XVIDs or DIVX files, try VSO DivXToDVD. It works well and is freeware.
For other AVI files, TMPGEnc or similar stand alone encoders are generally the way to go for the best quality. -
If the finished file is 1.5G, is there any way to put atleast two files on one DVD?
Originally Posted by cjstylee"Art is making something out of nothing and selling it." - Frank Zappa
Avi and avchd to DVD - 2 questions in 1
By merovingio in forum Video ConversionReplies: 1Last Post: 15th Oct 2011, 12:22 -
AVI to DVD Questions
By RdM642 in forum Video ConversionReplies: 2Last Post: 6th Feb 2010, 21:30 -
Tech. questions! avi/mp4 to CD to DVD?
By OverrRyde in forum Newbie / General discussionsReplies: 5Last Post: 10th Sep 2009, 19:22 -
Newbie questions on converting avi to mpeg2 and dvd authoring
By mlcampbe in forum Newbie / General discussionsReplies: 3Last Post: 4th Mar 2008, 13:08 -
I have converted avi to vcd and svcd im looking to convert avi to dvd
By dbztoolkit in forum Newbie / General discussionsReplies: 1Last Post: 11th Jun 2007, 12:14
