Closed Thread
    Feb 2005
    Hi,
    I asked this in the DVD to DVDR but didnt recieve an answer in over a week. So I thought maybe it was because this is move of an editing question rather than a DVD Back up question. Anyways, when I back up a DVD, I usually use VOBBlanker to get as much space as possible, sometimes making still menus and sometimes not. Either way I always disaggle the menu button that leads to blanked files. I was able to find this guide for doing this with a still menu: http://dvdguides.netgeekhosting.com/guides/edit_menu/ It works perfectly fine with the still menus. It also works good with disabling the button on a motion menu that I havent needed to turn into a still. The problem is when it talks about editing the BMP to erase the words "Special Features" or whatever the words for the button were. Once again, it works fine with stills, but how will I get it to work for a motion menu? So that the words are gone for the entire animation of the menu? I hope my question makes sense. I tried to edit the picture and get rid of the words for the entire motion menu using the guide, but since the BMP is a still shot of the menu, it doesnt erase the words for the duration of the menu. Is there a way to do this? Thanks.
    Check out the Band...feel free to PM me with opinions: http://www.purevolume.com/beneathitall
    please don't cross post. bump your old topic instead.
    https://www.videohelp.com/forum/viewtopic.php?t=268709&highlight=
