When I try to burn an image the write sped box is greyed out and it wont let me select a speen other than MAX. I would like to burn my dvds at 4X or slower, is there a way to do this?
You could burn with something else. Output to dvd folder in tmpgenc dvd author and burn with for example nero burning rom, copytodvd or imgtools and dvddecrypter.
Upgrade to 1.6 and it will let you select speed. You should be able to upgrade for free.
Well there you go - I could not work out if there was any difference between 1.5 and 1.6 (Got both), but as I am a cheapskate, and can get single layer DVDr's for 1/10 of the price of Dual layers, I have not bothered using 1.6, as I though dual layer support was the only change.Originally Posted by samijubal
DVD-r Footage menu wont navigate ! Re- Author ?
By rockonvidtrade in forum Authoring (DVD)Replies: 2Last Post: 3rd Oct 2009, 18:42 -
Tmpgenc dvd author 3 will not author my m2v files????
By biged670 in forum Authoring (DVD)Replies: 1Last Post: 28th Sep 2009, 12:10 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 16:07 -
TMPGEnc makes deep/slower sounding audio
By awesomer in forum Video ConversionReplies: 8Last Post: 28th Oct 2007, 01:46
