I want to buy a capture card. My purpose is
1> supports editting software and also view timeline to monitor & TV same time.
2> caputure MPEG-1 & MPEG-2 format video from RCA,S-video and also Fireware port (DV port) through hardware or software.
3> capture in MPEG-1 & MPEG-2 format video no audio sync error and very good quality ( no noise , no mosasic)
4> Good quality capture from old VHS cassetes and Hi-8 camera.
5> Realtime effect can be applicable.
can any suggestion and with experience about good quality card. thanks
Little Baby
u opened the gates of hell really. this discussion could go on for months without u getting ur answer. keyword here is : BUDGET.
how much r u willing to pay. for the purpose u suggested we can safely put out the 30$ usb 2 converters. so we're left with actual cards.
for that u can check this link here.
http://vcdhelp.pricegrabber.com/search_attrib.php/page_id=336
my personal experience with Matrox was great, so if budget is no issue, u can treat urself with a massive RTX100 from Matrox.
Good Luck
VERVEGod Bless Lebanon... -
Your other post indicates you have already purchased Canopus Edius software. Your first option is to evaluate the supported realtime cards for that software: Canopus DVRaptor RT2, DVStorm and DVRex RTOriginally Posted by diginode
These cards allow import of DV or analog video (ADVC option) into a realtime DV editing environment. That is what you were requesting on the other post.
Evaluate this package as an entry point and move up to higher hardware if you think you need it.
http://www.canopus.us/US/products/EDIUS_DV_Pack/pt_EDIUS_DVpack.asp
As a separate project, get a hardware MPeg capture card like a PVR-250 or higher if you can afford it. -
For the budget u stated u definetly can go for MATROX RTX100 with Adobe Suite that includes Premiere Pro + After effects +Encore + Audition if u dont have them aready.
If u do have them u can get the card for around 700$ or so.
Not sure about ur Nvidia graphic card though, u should check on there site:
www.matrox.com
If what edDV said was true regarding Canopus, I guess u have some research to conduct on ur own to check for compatibility. The link I provided in my earlier reply would help.God Bless Lebanon...
Capture card for Laserdisc and VHS - Good card/quality
By darkbluesky in forum Capturing and VCRReplies: 85Last Post: 21st Mar 2012, 13:27 -
Connecting TV Tuner Card / Sound card for best audio capture??
By pukhog3 in forum AudioReplies: 9Last Post: 14th Aug 2009, 17:13 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
Quality of a DVB/Tuner card ; but simplicity of a Capture card.
By BATGAL in forum Capturing and VCRReplies: 3Last Post: 1st Oct 2007, 11:51 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
