Hello, where can i get a (cheap) Kvm switch w/audio.
Thanks![]()
Keep in mind that most of the cheaper ones restrict/limit the video resolution. You won't find a cheap kvm switch that lets you play DOOM 3 at 1280 x 1024 at 85hz.
Google is your Friend -
I purchased one and hated it. The audio shareing on it sucked. Trying to remember the brand though and pulling a blank, they are usually considered decent. The whole switched worked fine except the audio which blew.
I need KVM switch help, re: DVI and D-Sub cards..
By sdsumike619 in forum ComputerReplies: 4Last Post: 14th Dec 2010, 23:51 -
Recommend a good USB 4 port KVM
By kenmo in forum ComputerReplies: 2Last Post: 29th Jul 2010, 11:57 -
KVM question
By gsh in forum ComputerReplies: 7Last Post: 28th Jan 2008, 14:25 -
Monitor split for high resolutions? (KVM)
By lordsmurf in forum ComputerReplies: 9Last Post: 5th Dec 2007, 15:30 -
display problem switch from pc to tv, can't switch back
By samiam5156 in forum ComputerReplies: 1Last Post: 11th Oct 2007, 09:23
