I worked a hell lot with the Subtitle Workshop, but, despite a lot of efforts, the subtitles aren't rightly synchronized. I don't know the reason too.
Pls suggest any other software which can synchronize the DVD video/audio with the subtitles.
Subtitle Workshop is the best.
Have you read the help file carefuly? Learning from the help file is a key to a success with SW.
Are you applying the correct frame rate?
Some times you have to synchronize subtitle lines in groups or even one by one.
You could try Winsubtitler, if you insist on other subtitling software.
Suggest A Good Video Editing Software
By Jedi5 in forum EditingReplies: 10Last Post: 9th May 2008, 12:56 -
Can Anyone suggest some REALLY REALLY basic easy editing software
By Jan29 in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 22:04 -
Suggest Video Editing Software
By Bald Eagle in forum Newbie / General discussionsReplies: 1Last Post: 19th Jan 2008, 13:27 -
Pls suggest a good inexpensive DVD burner
By phildis in forum DVD & Blu-ray WritersReplies: 4Last Post: 20th Nov 2007, 12:29 -
Pls suggest compact Video format for episodic storage on DVD-R with menu
By Firewire60 in forum Video ConversionReplies: 2Last Post: 10th Jun 2007, 04:37
