hi just wondering if anyone can help on this mater ive tryed to copy 3 different svcd to dvd each containing 2 parts ( only one film on each dvd)
it merges the disks ok in to 1 film but doesnt copy the whole film seems to stop about 75% of the film i think missing the last 25% am i doing something wrong ive tryed quick dvd and manual still the same
btw this is the first ime ive used this programe so it could be some setting im missing ive read the tutorial and dont seem to be doing anything wrong
Results 1 to 10 of 10
its a registered version mate just downloaded it yesterday the newest one
Hi tam30over. Does the progress indicator stop at 75%? Have you checked to see that you have the correct amount of BUP, IFO and VOB files in your VIDEO_TS folder? There should be twp BUP's, 2 IFO's and the amount of VOB's will vary but add up to the size of the merged mpeg. The reason I ask is because there is a small glitch with svcd2dvd whereby the indicator will not reach 100% even though process is complete.
Cheers -
i think the prog went to about 98% and i didnt check the video ts folder mate im going to try again today with the same film so i will have a look at that cheers
please if anyone else has any ideas let me know im getting some coasters trying to get this programe to work for me ( probably my fault but its how to learn) -
Sorry mate, I may have misinterprated your prob. Does the burned DVD stop at 75% when you playback on the telly? Have you used the autofit button as well as the merge button? and have you checked "use pulldown" from the settings menu. Another point to bare in mind is whether your file system is FAT32 or NTFS. The max individual file size on a FAT32 formatted system is 4.0GB ( minus 1kb for accuracy ) and therefore a FAT32 formatted system will stop processing when the file reaches 4 gig in size.
Cheers -
this is the settings i have mate and yes it is when i play back on a dvd (i loss the end of the film)
my drive is also formatted to ntfs
i didnt use auto fit as it was 1 film (svcd) i put onto dvd which was about 1.5 gig only.
i also checked the video ts folder and it has all that you say in it
cheers for your help -
Have you checked the SVCD files on the hard drive before conversion?
Have you checked the S2D created files to see if the movie is all there at that point?
Have you played back the created DVD files on your PC to check before burning? -
CAn you email me your log file to analyse?
hi guys i think its sorted now just burned 2 differet svcd ( the same ones i already tryed before) and they worked ok what i did was deleted the demo version from my computer completely it must have had something to do with me having that still on my comp even though i was still using the full version to burn, well it works now and thats the only thing ive done different............ only explanation i can think of.
thanks for the great response on helping me on this matter and its a great prog btw
tam
Please help, problem adding assets to svcd2dvd
By stevea99 in forum SVCD2DVD & VOB2MPGReplies: 1Last Post: 6th Mar 2011, 17:05 -
registration problem SVCD2DVD
By stgreene in forum SVCD2DVD & VOB2MPGReplies: 9Last Post: 8th Nov 2009, 01:32 -
svcd2dvd problem
By dvds2u in forum Newbie / General discussionsReplies: 1Last Post: 27th Mar 2008, 12:05 -
problem activating svcd2dvd
By tecker in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 20th Mar 2008, 22:20 -
SVCD2DVD problem with TS files
By rickfaldo in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 26th Dec 2007, 12:14
