hi folks. i'm trying to put 2 films on one DVD. i have 1 x movieA.ISO 1 x movieB.avi
movieA is NTSC (29.97 fps) and movieB is PAL (25 fps)
movieA is 1.4gig and movieB is a 700MB DivX
if i go ahead and convert movieB to a PAL MPEG using TMPGEnc Plus and then author a DVD with both tracks using TMPGEnc DVD Author, will it play ok on Australian (PAL) DVD players? i'm a bit stumped as i'm kind of new to this.
thanks heaps for your time![]()
Results 1 to 11 of 11
Heck is where people who don't believe in Gosh go
Cannot mix PAL and NTSC on the same DVD, but if you convert the NTSC to PAL and both to MPEG2 format that you can author to VOB format with something like TMPG DVD Author, it works.
If you don't want to convert one to the other format you can author on seperate discs, I've seen it noted that most standalone players in PAL land will play NTSC discs.
thanks all. much appreciated
Heck is where people who don't believe in Gosh go -
Authored as seperate titlesets is a) unsupported by many authoring tools, and b) not in the DVD spec. Expect it to play on some PAL players and almost no NTSC players. DVD Lab is one of the few tools that will author it, but you have to turn compliance off and you will get a warning. Shrink apparently can pull them together, but the same caveats regarding compliance and playability hold.
Read my blog here.
It is possible without reencoding, have a look here:
https://www.videohelp.com/forum/viewtopic.php?p=1295349
That method of JohnsO sounds like a good one. -
Out of spec.
Make two discs. Or convert one file.
I'd personally just make two discs.Want my help? Ask here! (not via PM!)
I do it all the time. Run each file individually through DVD Author. Now you have 2 DVDs. Run DVDShrink and choose re-author. Drag both titles into the project. No menus, but PAL & NTSC titles on the same disc. Any DVD player that can output PAL & NTSC will play it....in my experience. Usually any of the APEX or the like (of which I have a few) will play it no problem. Obviously not the best solution, but if its not for archival purposes who cares.....
Pls help! Best way to convert NTSC VHS (captured using PAL VCR) to NTSC DVD
By rairjordan in forum Capturing and VCRReplies: 33Last Post: 28th Nov 2013, 11:33 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 12:57 -
DVD players that play PAL & NTSC - do you need a PAL television?
By ibzomie in forum Newbie / General discussionsReplies: 9Last Post: 12th Dec 2010, 20:53 -
Creating NTSC Blu ray DVD From PAL TS Files. need help with NTSC format
By Rick0725 in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Apr 2009, 21:43 -
PAL VCD -> NTSC Video for NTSC DVD Authoring!!
By Mickey79 in forum Video ConversionReplies: 5Last Post: 12th Aug 2008, 11:30
