I have an avi file and srt subtitle file, I want to convert this to VCD format with permanent subtitles. So I followed the guide here wherein the tools used is Tmpgenc and Vobsub. This method does not require frameserving.
Everything work fine except that when you play the output vcd file, there are some scenes wherein the subtitles does not appear. Only a few minutes of some scene. I am trying to figure out what I need to do to be able to correct this. I had tried uninstalling vobsub and installing the latest version but the result is still the same.
I hope someone can give me some advice or suggestions as to how can I solve this problem. I have been stucked to this problem for a very long time already. It seems it is only me who has this problem cause I had searched the forum and did not find any similar case as mine.
Any help will be greatly appreciated.
	it happens for some...i don't know why yet. you could try ffdshow instead or you can use virtualdub with the vobsub filter and frameserve to tmpgenc.
 https://www.videohelp.com/guides.php?guideid=116&howtoselect=5;20#116
  m4v subtitles (vobsub)By roughsporty in forum SubtitleReplies: 2Last Post: 18th Mar 2011, 09:04
  VobSub extracts subs but don't displayBy den207sco in forum SubtitleReplies: 6Last Post: 23rd Jun 2009, 09:12
  VobSub subtitles to SRT,how?By jepe in forum SubtitleReplies: 4Last Post: 14th Apr 2009, 14:49
  Permanent Subtitles with VobSubBy daniscp in forum EditingReplies: 0Last Post: 18th Dec 2007, 09:42
  Subtitles using VobSUBBy rafael_laffront in forum SubtitleReplies: 0Last Post: 8th May 2007, 16:39
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
