Is there any good editing software that is easy for newbies to do all of the following:
-Cut out parts of video that not wanted
-Join files together
-Edit in a bunch of clips into a new video file if i'm interested in creating one
-will work with avi,mpeg,wmv and popular formats?
anything that can do all of this, and hell, if it's easy enough for a newbie to learn, then even more.....don't care if it's something like ulead etc....what would you guys recommend?
thank you!
Results 1 to 9 of 9
Keep in mind that Windows Movie Maker can not be un-installed once installed and it will probably require some fixes in order to keep it from crashing.
bits -
I know it comes with it,Not sure about 2 years ago. But I think version2 is an upgrade.
How do I edit, cut, join DVDs, VOB, VIDEO_TS folders
By Baldrick in forum Authoring (DVD)Replies: 14Last Post: 8th Dec 2025, 11:01 -
Edit/Join
By ghforlife in forum EditingReplies: 7Last Post: 16th Dec 2011, 18:06 -
mpeg4-ts - how to edit? Need to cut fragments and join two files
By relu84 in forum Newbie / General discussionsReplies: 2Last Post: 18th Jan 2011, 08:01 -
Software TV Studios use to edit/cut splice logos & commercials etc....
By Moontrash in forum EditingReplies: 11Last Post: 14th Oct 2010, 23:52 -
which software can edit(cut&joint)rmvb?
By ptr866 in forum EditingReplies: 5Last Post: 1st Jun 2008, 12:56
