New to ripping. Running amd 1200,windows XP syst. Smart ripper 2.40, DVD2AVI 1.76 and TMPGE 2.02.31.119 along with Nero 5.5.5.6 .
When i run smartripper, the 8 chapters are checked off on the movie (sorpranos) (which i own) when its done ripping, i only have 5 and sometimes 6 chapters ripped ? can any one help me solve this problem ?
Also in tmpgeng, how can you tell or set the apx. time or size for encoding so it can fit on a 80 min. cd ?I encoded 1/2 the total frames of the movie 0 to 158257 frames. total frames are 316414 and got error message (too large for media).
would appreciate any help as i am VERY NEW to this,
Dreamer
i am still kind of new myself but had the same problem you did. When you think about it, your not getting the whole VOB file, so after you have loaded up the DVD and are getting ready to rip, go to your "setting" tab and i believe the default is set at 4000 mb, so change that to a higher number like 10000 mb.Try this and let me know.
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
Thank you for the quick reply, ill try it. What is the 4000mb? does that mean its apx 4 gig limit?
Dreamer -
On 2001-12-15 06:30:50, pinoy2201 wrote:
that means it is a 4gig limit to ripping an Vob
Dreamer
Can't read disc/ripped VOB files
By koberulz in forum Newbie / General discussionsReplies: 11Last Post: 18th Oct 2011, 13:34 -
Trouble with Ripped DVDs/converting .VOB to .AVI
By research in forum Video ConversionReplies: 1Last Post: 15th Jul 2010, 15:42 -
Encoding .DV problems with ffmpeg (e.g. MPEG4 -> DV or VOB -> DV)
By AlphaMonk in forum ffmpegX general discussionReplies: 1Last Post: 23rd Feb 2010, 04:24 -
Ripped VOB #1 wrong aspect ratio, all others ok!
By silver007 in forum DVD RippingReplies: 8Last Post: 6th Jun 2009, 11:01 -
Converting ripped VOB to a .mov WITH SOUND....
By elmo7082003 in forum MacReplies: 3Last Post: 9th Oct 2007, 23:52
