  1. i was screwing around and organizing my start menu, and i accidentaly moved the "startup" folder onto the desktop (it copied there) - now i have the startup folder in the start menu (which is fine) but i also have it on the desktop and windows won't let me delete it - which is annoying. How can i delete this startup folder off the desktop!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Next time, in the subject heading, please describe your problem rather than just a general "help me". Thanks
    /Mod Offline
  2. System restore?
  3. Greetings Supreme2k's Avatar
    Feb 2003
    Right Here, Right Now
    Try dropping it back on the start menu. It will probably ask if you want to replace, so choose Yes.
