First off, I would like to thank Borax for this program. It's a real winner and Free! Okay now that that's over with here are my questions:
1) I am getting an error that kills the DVD Creation when i use a Muxed (.mpg) file. If i DeMux the files and then add them, everything works great.
Any idea why? I can load the Mpg files in DVDStyler and they work fine.
2) Is there a way to edit the .xml file or the avisynth file that creates motion menus? I've heard it being talked about but can't figure out how.
Thanks in advance!
Rog
There are many ways to measure success. You just have to find your own yardstick.
Concerning your first question: What kind of error? Run Time Error of GFD itself, or authoring error from one of the commandline programs? Is the log file created? If yes, could you send it to me?
2. That's quite easy: Instead of using the "CreateDVD" button, use "CreateBatch". After GfD has finished to create the xml, avs, bmp and bat files, edit the avs and xml files (in the temp folder) as you like. Start the authoring with the MainBatch.bat file if you have finished your modifications.GUI for dvdauthor:
https://www.videohelp.com/~gfd/ -
Can Do. Can i PM it to ya or email?
RogThere are many ways to measure success. You just have to find your own yardstick.
Which to use, DVDAuthorgui or "GUI for dvdauthor" ? Or DVDauthor in batch ?
By halsboss in forum Authoring (DVD)Replies: 2Last Post: 1st Feb 2010, 12:00 -
questions about using GUI for DVDauthor to author DVD
By jimdagys in forum Authoring (DVD)Replies: 8Last Post: 2nd Dec 2007, 20:08 -
GUI for DVDAuthor
By netbuddy in forum Authoring (DVD)Replies: 35Last Post: 15th Nov 2007, 06:12 -
GUI For DVD Author - A Couple of Questions
By deadwing in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2007, 02:25 -
gui for dvdauthor HELP
By dontpanic in forum Authoring (DVD)Replies: 10Last Post: 4th Aug 2007, 07:47
