Results 1 to 12 of 12
    Sep 2004
    Belgium
    Hi,
    Is it possible to crop a few cm from the bottom of a dvd video without losing quality?
    If so, please help me! Because I know you can crop an avi but can you crop a dvd too?????
    Thanx,
    Jelle
  2. Yes, but it means you will have to re-encode. Any changes like that require re-encoding. And as its DVD, re-authoring too.
    There are 10 kinds of people in this world. Those that understand binary...
    Sep 2004
    Belgium
    And wich program do i need for that? Or is their a tutorial somewhere to do this?
    And a last question: do i loose quality?
    Yes, lose quality.
    Apr 2002
    New Jersey
    Well..if you find you can not crop it...try flogging it!
  6. Originally Posted by Jelleke
    TMPGenc can do do it, yes you lose quality.
    Sep 2004
    Belgium
    It won't work with TMPGenc with me
    Can't I do it with dvd lab??
    Sep 2004
    Belgium
    Originally Posted by Scooter_NJ
    Wflogging it!
    Flogging?
    By the way, I have a .M2V file (so mpeg2) isn't their a way to crop that without losing quality??
    A DVD cannot be edited like that. I have a feeling you're trying to open the DVD in software.
    What you CAN do, however, is decompile the full DVD back to source, re-encode the video part, and then re-author. It takes time, it's tedious, and it will lose quality. But that's how you do it. It's going to take some reading.
    EDIT:
    Wflogging it!
    Flogging?
    So you have the M2V file? Be sure there is an MPEG2 decoder installed on your system, then load the file in TMPG, use the crop filter (mask it) and then encode the new file.
    Sep 2004
    Belgium
    It won't work.
    Program allways crashes if i want to do it.
  11. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Why do you need to crop it ?
    Read my blog here.
    Sep 2004
    Belgium
    Because their is a text at the bottom of the dvd that i want to remove.
