I burned some video files onto my computer, and everything works fine...its just that the subtitles are really small and are at the very bottom of the screen, sometimes cutting of half of the words. I used TMPGENC Xpress to convert using 1:1 ratio, because that has worked for me in the past when dealing with subtitles. But is there a more extreme ratio I can use that will somehow push the subtitles up? Or is there anything else I can do?
All help is appreciated,
Thanks,
Dain
[img]vba02cbbfe6.gif[/img]
are you using vobsub/vsfilter? then change the font size in the configuration.
or is it permanent subtitles in the video that you are converting to dvd?
moving you to our new subtitle forum. -
thank you baldrick, sorry I didnt see/know about the subtitle forum.
I havent used vobsub or anything like that, its an extra process Ive been able to skip before, I just convert the avi file with subs to mpeg then burn. Is the only way to change subs to use vobsub?[img]vba02cbbfe6.gif[/img] -
is it permanent subtitles???? then you can't change the size.
is it subs that you can switch off? then you must have something that adds them on the video like vobsub when you convert with tmpgenc xpress. -
if you play the avi with the subs do you see a green arrow in the notification area?
hmm, actually with this I dont see the green arrow come up as it does with other anime files....maybe it is permanent?
Saving view
By jyeh74 in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2011, 15:18 -
How to view .mpg video and subtitles in QT Player?
By davecc in forum MacReplies: 6Last Post: 26th Jun 2009, 09:22 -
How can i view my PC on my TV?
By awaisuk in forum Capturing and VCRReplies: 8Last Post: 23rd Jun 2009, 08:24 -
View folder changes
By jyeh74 in forum ComputerReplies: 5Last Post: 20th Oct 2008, 02:18 -
Sansa View 8 GB Model how do I convert video for use with the sansa view?
By goheadtry in forum Video ConversionReplies: 1Last Post: 2nd Jun 2008, 01:01
